Caledonian Sleeper
ginge8991
22 Jan 2014
Does anyone know if the Caledonian Sleeper is fitted with WiFi or any other entertainment systems for seated passengers.
SeanG
4 May 2013
No, it is not.
However the whisky in the evening and scenery in the morning is all you need (if travelling north)
nlogax
Mostly Glasgow-ish. Mostly.
No, it is not.
Absolutely. Depending on the timing and carriage you're sat in, 60 inch widescreen views of the Highlands are available, beautifully 3D-rendered in real time and at 4k resolution.
jopsuk
13 May 2008
As said, no. There's also no 230V sockets in the cabins- there's a small number for public use in the lounge car.
tsr
15 Nov 2011
Between the parallel lines
Smaller & less power-consuming electrical devices, such as phone chargers, can often be used with a UK-to-Continental Europe adapter plugged into the shaver sockets in the cabins. Whilst this is not officially noted, it appears to be a very well-known trick and by no means forbidden (though doubtless at one's own risk!).
gazthomas
5 Jun 2011
Llandudno
Should be fine
FQ
Quizmaster
4 Oct 2013
In which case, it'll have to be the whisky and the scenery in the evening - all in one go! :p
Unless you don't/can't drink whisky/beer/wine and you fall asleep before leaving Inverness. ;)
route:oxford
1 Nov 2008
Or just use a euro-usb socket. Can usually pick them up for a few £ on Amazon.
I gave up carrying adapaters a few years ago after I'd bought a supply of various plugs and cables (eg US - cloverleaf or US to Kettle) for the countries I visit.
