Caledonian Sleeper
tadhatter
17 Jul 2012
Rugby
Anyone know why it is empty and in the Southbound loop at Rugby this morning?
sd0733
7 Nov 2012
It failed at Crewe, not sure what was up with it but it blocked platform 6 until at least 6:58. All the passengers were being put onto the 7:22 Virgin service to euston.
CallySleeper
27 Jun 2006
trentbartonland
1M16 was curtailed at Crewe last night, apparently because of a problem with the class 90. It's supposed to be moving from Rugby to Wembley CS via Northampton at around 1135.
tadhatter
17 Jul 2012
Rugby
Ok thanks. 90029 in DBS colours is currently on it - presumably that wasn't the loco that failed?
sd0733
7 Nov 2012
Unsure of the number but it was a DB red 90 when it got to Crewe.
Dave1954
11 Mar 2013
That's a bit of bad luck on the passengers especially the Sleepers:(
keith43003
17 Feb 2014
Was on this. 90029 collapsed with knackered ETH at Crewe. Lick of paint solves all your problems!
Mark62
3 Apr 2014
Were they still in their pyjamas?
Sorry for being thick but what's the gsmr please?
Great question.It could stand for
Great Milk Stout Ride
Green mountain stage race
Global System for Mobile Communications
Granite State Management and Resources
Gay mens spiritual retreat
Great societies melt radiators
Golod and Socialist Moshehai Republics
I have no idea what gmsr or gsmr etc stands for. Why can't people just speak plain english? Or is that too easy?
In a special interest forum, it's not unexpected that people will use acronyms that are related to the special interest. The only 'mistake' (if there was one) is that it should be written GSM-R.
TheGrew
31 Jul 2012
GSM-R is just a subset of the GSM standard (Global System for Mobile Communications) for rail comms
Sent from my Nexus 4 using Tapatalk
Nean
28 Dec 2013
Sheffield
GSM is the overarching term for most or all (that part escapes me at the moment) of the 2G telecom network. GSM-R is the version designed for use on the railway... it's the official and common-use term for it and so the "plain english" for it is no different than saying, for example, SPAD instead of "Signal Passed Against Danger", however SPAD is more straightforward than saying "The globally used telecommunications protocol with specifically designed features for use the railway"
It's a case of that it was a specific failure to the GSM-R module and so that's what people will report it as (and if you don't know what anything means, there's always google-fu)
Most. There are/were other technologies used for 2G/3G networks - e.g. CDMA is/was used commonly in the USA.
deltic08
26 Aug 2013
North
And no other loco of any description at Crewe to stick on the front as pilot? Customer Service on the railways has gone to pot with privatisation.
There probably was a loco, but it may not have belonged to EWS. Also, would the sleeper have fit on the platform at Euston with two locos on the front?
cjmillsnun
13 Feb 2011
The loco could move under its own power. It's just that it could only go to depot as the GSM-R wasn't working.
I would be very surprised if there wasn't a DB loco around at Crewe of all places.
tcm1106
4 Jan 2010
http://lmgtfy.com/?q=gsmr
There was a spare 92 at Crewe but no driver immediately available.
The decision was taken to run ECS (that's Empty Coaching Stock for those acronym pedants) to Rugby with the intention of doing a loco swap there. In the end a fitter attended with a new GSM-R set and swapped it out.
