BRX
- Joined
- 20 Oct 2008
- Messages
- 4,568
Brake force I thinkFantastic video. Great to see them finally in the UK.
Obviously barrier/translator vehicles are required because of the Dellners, but what are the flat wagons for?
Brake force I think
No, you are probably right and I'm likely completely wrong!I thought that that was only required for the tunnel move with a non-delnner fitted loco. I just assumed the wagons were left on to get them back to Wembley and the move forward tonight will see them removed. I could be completely wrong though?
Not all Dellners are the same.
Stock is dual pipe, but pneumatics are through the coupler.
They are more like the flat wagons used for steel ingots that I see coming past on their way from Scunthorpe to the channel tunnel. Timber wagons have sturdier and higher uprights along the sides.They look like timber wagons. Do we export timber?
How exactly can a dellner differ?
The second sentence makes no sense to me, sorry. Surely dual pipe and through the coupler are opposites?
Different sizes and different heights.
Dual pipe is a method of supply and control. The pipes are connected through the coupler which has a pneumatic addition.
Just been told it's going back to Dolland's Moor due to a problem with the paperwork!!
Why do they always have to make it so difficult?
I fail to see the issue with standardised buckeye/tightlock and bagpipes. Adds redundancy.
do Alstom at Polmadie have a loco/shunter with a dellner to enable them to shunt it/them, or will they rely on GB 73s in the short term
Nothing like good old joined-up thinking.
Not as far as I know but they may have a barrier vehicle they can use with a pilot loco. Do the couplers not drop to reveal a drawhook in case of emergencies?
Has it left Wembley for the North yet... is so may pop to Crewe in a bit to see.
They must have faith in those inbuilt tail lamps since there's no lamp brackets...
Yes, the 92s (like the 73/9s) will retain the drawhooks, with the Dellners able to drop down, so that they can continue to be used on freight work and classic stock. Like the 73/9s, the buffers on the 92s will also be retractable so they can be moved back in "Dellner mode" and then brought forward for conventional stock.As I underand it, and by looking at the pics of the couplings Tam posted a few pages back, the coaches only have Dellners, no drawhook. The 73s (and presumably the 92s?) retain their drawhooks alongside the Dellner.
I know Polmadie has 2 08s, not sure if either of them have been/will be given a Dellner attachment. Never seen a barrier vehicle when passing either, but that's not to say there isn't one.
