92014 failed I believe.
Sam
Sam
Does anyone know what happened to last night's Down Lowland Sleeper (1S26)? Appears to have failed just outside Birmingham and then been rescued after c.3 hours?
Passengers on board complaining of cold, so also assuming rescue loco didn't have ETH?
Quicker and sleeper don't often go together.Must be some engineering works around Nuneaton area I guess, although I would have thought running up through Wolverhampton would be quicker than Bescot?
I can add what I hope is also helpful: it is always worth asking here if anyone has a Flexipass ticket or two to spare.I'm assuming First Class? I've only got one helpful suggestion.
So that's four single journeys in two adjoining cabins, I don't know about the 'hound' nowadays, I think that Serco are reducing the fee for dogs. And remember you don't have to be ready to go until just before midnight and you'll be in for 8am.
You could buy a ten journey Flexipass for £1500, let £600 of it go on this trip and still have six single trips in hand for whatever takes your fancy over the next year: Inverness, Aviemore, Kingussie, Pitlochry, Fort William, Aberdeen, Edinburgh, Glasgow...
I've no idea about the £200 to get you to Euston, or the parking, but the sleeper isn't that expensive for business for those who know that they're going to make ten trips in a year. But I know, it's just so so expensive for those making a casual enquiry a few days before travel.
Would tend to agree with Night Riveria comment regarding Solo cabins - searching for random dates eg October 3rd (Monday) Cornwall -Paddington single cabins fully booked !!
Sam
I don't entirely understand why they do it that way, and why they don't just sell any cabin as either a single or a twin depending who books what when, just as hotels do.
And it'd been doing so well since it's "modifications"![]()
Whilst I agree with you here I suspect we will get an outbreak of posters saying just how good 92s are and how long 1 hasnt failed for.
Well that's it then. Goodbye 92's for good it seems.. If they can't even work after modifications then the only place they will go is HS1. Can't see Brush wanting to look at it anymore, rather scrap it and the others that don't or won't work.
I see your point Neil - but I think Cornish sleeper has gone from strength to strength since "1st class" cabins were consigned to history and the mix between solo and twin cabins works well most of the time.
They don't have a choice though. The new stock has a higher ETS requirement than the existing stock, so it'll have to be hauled by 92s, because the existing stock isn't powerful enough. The alternative solution is to fit a generator van to the rake, but that is then eating up platform space.
that would require through wiring to allow control from either end.There's enough space at Euston for a loco at both ends. If all else fails, then the train could run to Edinburgh/Carstairs in push-pull configuration using the rear loco to provide additional ETS.
I agree "1st class" is pointlessly confusing and that it should be a Standard class train with supplements. All I mean is that the mix of cabins should be based on who books what when. So any given cabin should be bookable as a twin or a single, so they shouldn't run out of singles or run out of twins, just out of cabins when it's totally full.
Unless you have exactly 2x the number of people booking twins as book singles you'll have either empty berths or people who can't book what they want.So any given cabin should be bookable as a twin or a single, so they shouldn't run out of singles or run out of twins, just out of cabins when it's totally full.
I didn't realise that gWr didn't allow sharing with an unknown person. In light of that, your suggestion makes complete sense.If sharing was permitted it wouldn't be an issue.
Yes, Scotrail used to offer Bargin Berths starting from £19 if memory serves correct.Am I going crazy, or did there used to be super-cheap advances called Bargain Berths available under Scotrail, for something like 25 quid? Now there's nothing less than 70 GBP (!), unless their fares don't show up in BRFares for some reason.
It would seem GWR have scrapped the policy of no sharing with a stranger, their website will allow booking of 1 berth in a twin cabin.
