Caledonian Sleeper discussion
TimboM
12 Apr 2016
Isn't it just more likely that it is due to driver availability?
There is still quite a lot of stunting to happen at Edinburgh - 73966 has to come off the back, 73968 / 73971 / 47749 have to come off the front and a 92 needs to go on
Assuming the 47 stays on, if 92043 had gone, once back at EDB 043 would have to drag (failed) 47749 off the stock, put it somewhere, uncouple from it, then go back on the stock. Using the 73/9s means once at EDB they can just unhook and run off with the duff Duff direct to Craigentinny and 043 then goes on - a simpler shunt.
Also the 73/9s already being off 5C11 means 1M11 can now run past and reverse back on to it without another move required to get them off the stock and out of the way.
TimboM
12 Apr 2016
92’s not cleared for queen street apparently. 2 x 73s not allowed either apparently.
92s are definitely cleared, as are 86/87/90.
Would be beyond the starting signal if the 47 stays attached though - but then the 73 will be too I think.
gsnedders
6 Sep 2015
I guess if you sent 92 043 they’d still have to shunt out the duff Duff once back at EDB. Also the 73/9s needed to come off 5C11 anyway. So actually having thought a bit more about it does make sense...
Is the 92 not providing ETH to the stock in Edinburgh while passengers board?
At the time of day by which it gets rescued, I imagine fouling the other platforms is hardly a concern!
Highlandspring
14 Oct 2017
A wee bit of confusion crept into things but as you say they do all have NRAP certificates clearing them.
The platform 7 starting signal is fitted with ‘standing out’ controls to allow it to be cleared with a portion of a train stating beyond it.
TimboM
12 Apr 2016
No - turns out just one 73/9 has gone to rescue 1M11, so likely the other is still on 5C11 providing ETH.
Agreed
11 Sep 2016
Bonsoir!
Enjoying reading the live updates of tonight's wacky workings here aboard 1S26 as the drama unfolds with some Thirsty Cross! -(I'm told I got my hands on the very last bottle onboard!!) Do keep them coming fellas!! :lol:
Forgive me for my ignorance, I appreciate that it most probably has been mentioned somewhere up-thread months ago but I have not logged on here in some time and just decided to bash tonight's historical first last night having read about it on here thanks to you guys and luckily been at a lose end this Easter Weekend!
But, can one of you gentlemen kindly shed some light on why were going to Queen Street tonight? I'm guessing one of the approaches to Central is closed for ENG WKS for the weekend somewhere or other, but where would that be exactly??
Many thanks in advance and thanks to all the gen posters out there, its been most entertaining so far! :D
1M11 is finally away from Queen St 137 minutes late
...and away from Edinburgh 148 minutes late.
For people interested in the shunting arrangements -
73971 remained coupled to the Edinburgh portion in platform 11. 92043 had been drawn forward from the Klondike siding.
1M11 arrived in platform 10. 73966 was detached from the rear. 1M11 drew forward into platform 7.
73971 then left the Edinburgh portion behind to shunt to platform 10 and attach to 73966. 73968 appeared to be the engine pushing the Glasgow portion back onto the waiting carriages rather than 47749
73968 and 47749 then taken off the front to shunt to platform 10 via Abbeyhill and join the two 73s. 92043 then coupled to the front of 1M11.
Meanwhile with attention on 1M11 the normal shunting of 1M16 was delayed. However, 0B01 and 0M16 were allowed to go to Craigentinny and the 92 for 1M16 move from platform 9 to 2 before 1M11 left.
1M16 left 52 minutes late 12 minutes behind 1M11. Let's see how the rest of this goes.
Oh, and 1S25 is waiting at Newcastle, presumably for the driver off 1M11. Seems possible that all four trains will be in the Newcastle area at once (not the station because there aren't enough suitable platforms)
Scotrail84
5 Jul 2010
Nope, driver for 1S25 went forward in a taxi long before 1M11 arrived in Edinburgh
Ah, right - just a guess as I noted 1S25 hadn't left Newcastle - in that case why was shunting of 1M11 (or appeared to be) prioritised over getting 1M16 out on time?
JModulo
17 Nov 2013
67A
1S25 still at Newcastle with 1S26 now stuck behind it on King Edward Bridge. The joys of waking up to the fire alarm...
Scotrail84
5 Jul 2010
Because 1M11 didn't have to stop at Newcastle for a driver change, 1M16 did so I believe
11 Sep 2016
And were off! The first ever electric locomotive-hauled passenger train over the E&G to Glasgow Queen Street (High Level)! The 73 has been tied on the rear for the ECS out.
jopsuk
13 May 2008
how long is the train into QS? Surely it can't be a full loco+2 mark 2 + 6 mark 3+ loco?
theblackwatch
15 Feb 2006
Judging by a few pictures I have seen, 90046 has successfully made it to Glasgow QS - glad it was a bit more successful that last night's departure from there!
ScottDarg
27 Apr 2017
South Lanarkshire
Same can't be said for the ECS it seems - posts elsewhere saying the 73 struggled up Cowlairs this morning, with the 90 seemingly pushing (pan up, driver in cab facing the coaches). Not sure how true that is at the moment.
If it is true, then I'd be surprised if they used Queen St again*. It seems like it's causing more hassle than it's worth and that it'd have been easier to run Glasgow Central - City Union - Bathgate - Edinburgh
*with the exception of tonights service, which is already booked out of Queen St
marks87
23 Jun 2010
Dundee
If that's true, then I'd be surprised if they used Queen St again*. It seems like it's causing more hassle than it's worth and that it'd have been easier to run Glasgow Central - City Union - Bathgate - Edinburgh
I don't know if last night and this morning will put them off Queen Street entirely. In true management speak, "lessons will have been learned". Which basically seems to be "don't use single-headed 73s or 47s" up Cowlairs.
Let's see how tonight goes with electric traction up front. I'd expect things to go a lot smoother.
If the worst thing they have to do in future is give a shove from the rear when the ECS is taken away, that doesn't seem a massive problem. But even if it were, a 73 could do the in-service run to Queen Street, with the 92 on the rear for ECS.
theblackwatch
15 Feb 2006
Yes I think I spoke too soon there!
Class 47s regularly took that number of coaches out of Queen Street in the 80s, so that shouldn't, in theory, be an issue.
bonzawe
30 May 2014
Is not a dead engine on the rear the equivalent of another two coaches.
