Caledonian Sleeper discussion
ScottDarg
27 Apr 2017
South Lanarkshire
That begs the question however, if it's got a defective cab, how does it move out of Euston?
Or are they allowed to drag a dead loco on ECS moves?
The loco's always dragged out of Glasgow so I believe it's alright for short hops like that.
Of course, I'm assuming it's a defective cab, could be another reason for it.
TimboM
12 Apr 2016
Yes - as Scott says, the Glasgow ECS moves (both evening and morning) always has a loco attached at both ends...
...the 5M16 (Highlander) ECS move every morning at Euston still has the 1M16 loco attached on rear;
The 5M11 ECS (Lowlander) ECS move in the morning at Euston varies - the usual approach is for the 1M11 loco to be left on the blocks and it runs round to take 5m16 back to Wembley (with 1M16 loco on rear as above). However, IF there is some issue with the (now) north-facing cab of 92014, it can be left on the back of the stock and go back to Wembley with 5M11; and 86101 can instead run back in after it's done 5M11 to take 5M16.
Are you thinking of the "ban" of running the Sleeper in service on the WCML with a 92 on the rear? If so, this is more of a passenger comfort issue due to the way the 92s are braked (or not!) in this formation which means they clatter into the back of the coaches every time it brakes resulting in plenty of jolting etc. Not an issue for ECS moves though.
GW43125
8 Dec 2014
That's the one. Thanks for clearing that up.
QueensCurve
22 Dec 2014
90042 on 1S26
87002 dragged it out under 5S26
Is this connected with the "technical issue" that is taking out tonight's run to Edinburgh?
Service alterations to Caledonian Sleeper services between London and Scotland
Monday 13 November - London Euston to Edinburgh
A technical issue with tonight's train means that the train will be terminating at Glasgow Central, and won't be calling at Edinburgh Waverley
Guests are advised of the following options to reach Edinburgh.
Leave the train at 06:55 Motherwell, and join the 07:06 Virgin East Coast service to Edinburgh, arriving at 07:52.
Leave the train at 07:20 at Glasgow Central, and join the 07:50 Crosscountry service to Edinburgh, arriving at 08:55.
Sleeper tickets will be accepted for travel on both these services.
ScottDarg
27 Apr 2017
South Lanarkshire
I think Scott was just meaning 87002 took the 5S26 ECS from Glasgow Central to Polmadie (as normal) with the 1S26 loco (90042 last night) dead on rear of the stock (as normal). Not that there was any issue with 90042.
Spot on, I realise how my phrasing can make it sound like there was an issue.
TimboM
12 Apr 2016
Thanks for pointing that out, hadn't seen it.
Not sure, someone else may have more info on it. I can only guess one of the locos has gone, or got flats again, and nothing else is available.
I don't know what the "technical issue" is but I don't believe it's a loco issue looking at the various other workings that are not cancelled (e.g. the Edinburgh-Carstairs portion southbound tonight) and the extra paths that have gone in (the only one being a light loco move Carstairs to Polmadie tomorrow morning - VSTP 0B26 - which leaves Carstairs pretty much same time 1B26 would normally go, so presumably using the same driver to take the surplus "Carstairs portion" loco back to Polmadie).
My best (un)educated guess is there's an issue with one of the two seated/brake coaches (or one's missing altogether) on 1S26 meaning the portions cannot be split - as the Edinburgh portion wouldn't then have a brake coach.
GW43125
8 Dec 2014
A "freight train" has failed at Blair Atholl but unless they need a new loco for the SB Inverness tonight, I can't see it being a problem.
47271
28 Apr 2015
It looks to me like the southbound Tesco train has conked out somewhere on the double line between Dalwhinnie and Blair Atholl. It's caused the cancellation of the two Scotrail services following it. It shouldn't interfere with the Sleeper, but these things have a habit of rippling on for hours on the HML.
GW43125
8 Dec 2014
In only slightly related news, the 21:31 Aberdeen-Edinburgh is cancelled and punters are being told they can use the sleeper as far as Edinburgh.
Far north 37
13 Apr 2011
yes is the southbound tesco train says a rescue loco has been dispatched
ScottDarg
27 Apr 2017
South Lanarkshire
90047 (I think, FL grey at least) away in with 5S95. Looks like 92014 is out of action tonight, with 90047 taking its place on 1S26.
That is, unless it went in on 0S25 (missed it on Railcam) and is working the Highlander tonight.
ScottDarg
27 Apr 2017
South Lanarkshire
Loco on 4D37 is 66431, reportedly overdue an exam.
Far north 37
13 Apr 2011
thanks for the info guy the tesco trains seem to be back to regular 66s now after the class 68s had seemingly taken over for a while
Scotrail84
5 Jul 2010
1S26 runs into Glasgow tonight with no split at Carstairs due to the brake van on the edinburgh portion being removed at Wembley due to wheel flats.
47271
28 Apr 2015
Nothing to do with the broken down Tesco train it seems, but I see the southbound Highlander was an hour late into Euston this morning, what happened there?
ScottDarg
27 Apr 2017
South Lanarkshire
Twitter feed mentions an unexplained issue near Bathgate that held up the Fort William portion.
They also noted the Up Highlander left Crewe 26 but then lost another 25 minutes between Hillmorton Jn and Wolverton, not sure what caused that.
Sleeper69
15 Sep 2017
When the full set (or in this case 15 on) it’s to long for platform 1, platform 11 is I believe the longest in the station, but you still have issues.
ScottDarg
27 Apr 2017
South Lanarkshire
That's what I was thinking. I know you could probably squeeze in another couple of coached and the ECS loco on P1, after that you'd probably be beyond the signal.
I believe you're right about P11 being the longest. I'm sure that was the platform used when the Class 50s came up with 13 (?) coaches + 2 leading locos and I believe it just fit, with the 90 used for ECS being beyond the end of the platform.
Blindtraveler
28 Feb 2011
Out of all the routes I use regularly the track via Kirknewton has been particularly bad this autumn I have noticed as has the shotts line
