Caledonian Sleeper discussion
louis97
14 May 2008
Derby
Just refreshed on RTT and it went to 53L, would that just be based on when it should have passed the next timing point or is it possible that it's going to reverse back to Carlisle and terminate there?
Most likely because the train was sat in the platform at Lockerbie. The 7 late report would of been the 'arrival' report, and then the 53 late would of been after the 'departure' report was received. At stations the passing time is formed using both the arrival and the departure reported times.
GW43125
8 Dec 2014
As there are no more trains off Aberdeen tonight, what's happened to the Aberdeen punters?
*EDIT* looking at twitter, it seems they've bussed them to Edinburgh for the Lowlander; which still hasn't left. Glasgow portion has already made it to Carstairs however.
Scotrail84
5 Jul 2010
Went down on the x/c service.
TimboM
12 Apr 2016
1M11 left Carstairs 50 Late having waited for the Edinburgh portion (which in turn was held for the Aberdeen passengers).
With a Freightliner 90 on it I believe (90042) + the 30 mins allowance in the timetable on Sunday nights for Single Line Working at Beattock not needed it should be back on schedule by Preston if not well before then.
TimboM
12 Apr 2016
With a Freightliner 90 on it I believe (90042) + the 30 mins allowance in the timetable on Sunday nights for Single Line Working at Beattock not needed it should be back on schedule by Preston if not before then.
1M11 was back on time by Preston but appeared to be delayed best part of 50 mins just after leaving. However still managed to arrive at both Watford Jnc and Euston 13 Early - in part helped by not having to go via Birmingham and also what looked like a clear run on the Fasts.
Not sure what the issue was between Preston and Wigan as 1S26 also suffered a similar length delay there.
TimboM
12 Apr 2016
Presumably the set that came up to Euston on 1M16 and now at Wembley is missing a few coaches for tonight's service if the Aberdeen portion didn't join up with it last night?
UPDATE: 73967 fixed it would appear and taking the stock back to Polmadie on 5B16
Path (0Z73) in for it to then to return to Craigentinny after stock dropped off.
Mag_seven
1 Sep 2014
here to eternity
1S25 subject to a late start due to driver taken ill on a Virgin service on the Down Fast at Berkhamsted (9G43). Down slow not available due to OLE damage.
Scotrail84
5 Jul 2010
1B01 84 late. Loco failure.
1S25 still in Euston.
The 90 for 1S26 trapped at battery end of 1.
Lowlander is 12 vice 16, with a brake van getting attached at Carstairs in the morning allowing it to split for Edinburgh and Glasgow.
Scotrail84
5 Jul 2010
Suicidal person sitting on a rail.
GW43125
8 Dec 2014
1) which portion will be 4v8?
2) is the train empty enough to move people to the other carriages or will day trains be involved?
LeylandLen
28 Oct 2013
Leyland Lancs
All Virgin trains and 1S25 stopped from leaving Euston now due to 9G44 to Wolves being stopped on down fast at Watford junction since 2038, believed illness on train .
Further investigation looks like 2003 IG43 stopped down fast Leighton Buzzard, on move now 2215
Chrism20
27 Feb 2013
Is this to enable the highlander to run with the full set due to Aberdeens being missing last night?
I didn't notice the portion that was cancelled last night sitting in or around Aberdeen this evening when I was in the station. I assumed they had shifted it in order to try and get everything back in place.
oversteer
26 Jan 2011
OHLE down on the down slow too..
VT saying member of train crew requires an ambulance, hope they're ok
Scotrail84
5 Jul 2010
Highlander would be a full set anyway as they swap sets in Wembley/polmadie everyday.
Scotrail84
5 Jul 2010
1S25 98 late and 1S26 expected to have a delay to departure due to late inward stock. 1B01 100 late last reported at rannoch.
TimboM
12 Apr 2016
Stock was taken to Polmadie on 5B16 this afternoon. However, those coaches should have been at Wembley with the rest of 1M16, so about 400 miles out of position...!
