TimboM
- Joined
- 12 Apr 2016
- Messages
- 3,734
It is a shame that tonight's sleeper has such a long wait at Wembley. I am guessing that they'll throw it in a siding there and attach another loco to it (the one that would normally take it back to the depot) before taking it back in to Euston that way. I assume this makes more financial sense to them that use running it into KGX instead which would save at LEAST an hour, likely more.
For the ECML diversions there's a loco on each end from the beginning (i.e. when the Northbound empty stock leaves Wembley in the evening). The one taking the train to Scotland is on the 'front' (Euston/South) end and takes the stock into Euston for boarding.
The one on the 'back' (North) then hauls the train back from Euston to Wembley Yard, where it is then detached. The one on the South end then takes the train South out of Wembley Yard to Camden Jnc (almost back to Euston - which confuses some passengers!) then loops round onto the ECML and finally heads North.
The reverse happens in the morning, usually with the same two "shuttle" locos attaching on the South end once the Southbound Lowlander and Highlander trains have pulled North into Wembley Yard for the drag-back to Euston. The "main" locos which brought the trains down from Scotland stay attached as they're then used to take the empty stock back to Wembley.
The wait in Wembley Yard (30-40 mins) is for the shunting movement to remove the extra loco and presumably for the driver to swap ends. If it's done quicker, and route is clear, it'll get going sooner.
As najaB has said, the 16-coach sleeper won't fit in Kings Cross (can only fit 12 coaches I believe + 2 locos). That's the main reasons it's not used, rather than cost.
