C2C 387s
43102EMR
28 Mar 2021
Southern? Posting elsewhere suggests they go to Hornsey first. I note the conversation above and post from 'Class 466' indicates that it isn't necessarily the six 387/2s on the GN that go south and does corroborate the Southern idea. Ultimately the point appears to be that Southern gets six 387s of some sort that can help with stock pressures.
Per this tweet: https://twitter.com/thetransporthub/status/1540659424892682240?s=21&t=R2GdYvF5naKFvVOjRN5xGg
Still no detail as to what/where they will be used, but I would assume Brighton fasts to internally cascade 377s.
12 Nov 2018
aleggatta
28 Sep 2015
If passenger numbers on GTR continue to rise, I think we could see intervention from DfT to accelerate this. Is there a time scale on this potential acquisition?
43102EMR
28 Mar 2021
The tweet did say “supposedly”, so it was not stated as fact - I was referring to the response to said tweet
The part about the c2c units leaving on Thursday in that tweet is wrong, they are still on lease until 23:59.
They’re moving next week, just not entering service until September.
Benno
28 Apr 2010
The units will go to Peterborough for storage, but at some point will need to go to Hornsey to have the relevant Mods packages to bring them up to the spec of the rest of the 387 fleet.
3973EXL
2 Feb 2017
STP 28/06 0V74 37510 0940 Wembley HS - Reading Traincare Depot
https://www.realtimetrains.co.uk/service/gb-nr:R00656/2022-06-28/detailed
5Q45 1341 Reading Traincare Depot - Peterborough Nean CHS 37510 387306/302/301
This service was cancelled between Acton Main Line and Peterboro Nene C.H.S due to a points failure (IB). 1734 arrived back on Reading Depot.
https://www.realtimetrains.co.uk/service/gb-nr:K03734/2022-06-28/detailed
1758 Peterborough Nean CHS - Wembley HS
https://www.realtimetrains.co.uk/service/gb-nr:R00711/2022-06-28/detailed
Jim
11 Jun 2005
Wick
303/304 still trundling around today on the usual C2C turn, 1P13 1P86.
43102EMR
28 Mar 2021
Supposedly, the GWR move is being caped - loco turned around at OOC to return West I’ve heard.
357
12 Nov 2018
The third 387 and two 720s are clearly visible passing Shoeburyness depot most evening peaks for what it's worth
Class15
30 Dec 2021
North London or Mildmay line
The thing to look for when this occasionally happens, (as can be seen here), is that all those odd passing times in red are increasing as you read up the screen. The new passing time overwrites the original time recorded when the service passed in the up direction. I think, and others might confirm, it usually occurs when the service uses the same ID throughout.
Class15
30 Dec 2021
Thanks!
fodphil
28 Sep 2019
Gloucester
301,302 and 306 are all coupled together on the front of Reading depot ready for the off whenever the loco turns up
43102EMR
28 Mar 2021
Are all the c2c 387s going over to great northern, if so when will they enter service with them?
I can only assume, but have also heard they might be used with Southern - aim for entry is the September TTC once pantograph changes/tracklink software has been implemented to the 3 with c2c.
Today’s 1P86 working cancelled due to “a problem currently under investigation”
physics34
1 Dec 2013
Could be used on southerns watford service
dereksingh291
Repeatedly returning banned member
14 Jul 2020
didnt the southern wcml services use the 377/7s before? not sure how different the /7s are from the 387s
yes they did then they used 377/2s. before the 377/7s came southern were using 377/2s.
Dual voltage. 100mph max
but the 387s have a max speed of 110mph
physics34
1 Dec 2013
Someone on here said those ones are 100mph max, i believe, because of pantograph
43102EMR
28 Mar 2021
The sticker inside the cab says 110mph.
Yes, but the c2c ones can only do 100 - different pantograph on them which caps them at 100mph max. The 3 that went to GWR had theirs changed to enable 110mph operation.
I’ve heard for use on the East Coastway and other Sussex locals, i.e. what the GX 387s did for Southern before Great Northern took them on.
Class 466
5 Mar 2010
Atherton, UK
GX 387s still work on the East Coastway and will continue to do so even after these 6 turn up
357
12 Nov 2018
Learn something new every day - I guess nobody bothered to update the sticker or speedo as they only do up to up to 75 in their current home.
