BVE4 Class 60/73
class 313
10 Dec 2005
St Albans
Hey,
I've been having the blue screen problem on the 60 and 73. Both are set to #0000FF and still are blue in the sim (OpenBVE), any help?
TIA
FusionRail
3 Sep 2007
Shackerstone
The 73, 60,1995/6 tube, 323 etc etc didnt work for me, but its easy to sort out.
Open the cabview of another train that works, and use the colour picker tool to select the blue colour of the window. Then open up the 60/73 cab image, and 'fill' the window with the colour you picked from a working train. It may not look like its changed colour, but save, then try OpenBVE again, its worked for all my problem trains.
jacknottm
8 Aug 2005
Tom I had the same problem with them mate even after changing them, Michelle explained it on the openbve forum, heres what Michelle wrote
http://openbve.freeforums.org/problems-with-cab-transparencies-even-after-correction-t269.html
I can confirm that for the Class 60, the panel2.cfg indicates (0,0,255) for the background while the color in the corresponding d3d\panelc.bmp is (0,0,254). And for the Class 73, the panel2.cfg indicates (0,0,255) while the color in the bv4\panel.bmp is (0,0,254), too. The fact that the corresponding parts in the bitmaps do no show up transparently is not a bug, but the intended way of processing the images. You can use Photoshop or Paint.NET among many others to query color values, but for Photoshop, you should not enable Web Safe colors as Photoshop will round the actual color queried to the next matching web color, which then is (0,0,255), giving you a wrong impression of what the bitmap actually contains regarding color values
Hope this helps
Jack
class 313
10 Dec 2005
St Albans
