BVE TMD Class 31
Smecty
10 Oct 2008
Wellesley, Mass., USA
Quick question: how do you start the Class 31 from BVE Traction Maintenance Depot? I've got the reverser in forward, the brakes are off, and no matter what throttle setting I choose (P1, P2, or P3) it just sits there! Clearly I need to get the thing started, but there's no hint of how to do so in any of the text files that came with the install!
[edit]
Oops, I see the commands at the right of the screen! :oops:
GWRtom
1 Jun 2008
Dorchester.
[edit]
first you need to put reverser into foward then back to nuetral cancel the beep
then press 2 and hold to started up then reverser foward again
jv3531
23 Jul 2008
Gloucestershire
It may have a DRA sequence fitted though, can't remember without running it. Pressing Space bar will reset DRA.:D
Aureol
29 Sep 2005
There are no locos in the BVETMD with a DRA fitted, only the class 56 has a parking brake, therefore the 31, 37/9, 50 and 73 don't need the space bar.
