BVE Route Randomizer
LondonBVE
22 Dec 2005
Lost!
Does anyone still have BVE Route Randomizer? When I visit the website it give 404 Error. I have got it, thanks Kelvin.
Aureol
29 Sep 2005
Sorry if this is a stupid question, but what does BVE Route Randomiser do exactly?
Coxster
9 Jun 2005
The most common use for it is to simply click a route and train of your choice rather than having to modify route files manually to use different tracton types with them. Additional features include making trains tilt, random signalling, adhesion levels, random track quality, random station wait/jam, random starter signal aspect and also timetable features. There is also a setting that can make your train take different lines but as you can guess this isn't exactly a realiable feature as you may end up travelling the wrong way on a line that is not bi-directional.
5 Jul 2005
House
Also I found it messed about with manually closing the doors, after one or two stops, it would just stop...
Boxcars
24 May 2006
Cambridge
In my honest opinion the BVE Route Randomiser (thanks to Oskari Saarakas) is an essential part of BVE. It makes changing routes and trains so easy. I wouldn't be without it, that's for sure.
Jordy
9 Jun 2005
WCML South
Always messes up signals with BVE4 here, don't know if thats just me though??
Coxster
9 Jun 2005
I've never had problems using it with BVE4. It's possible, Jordy, you may have v9 installed? BVE4 is only compatible with BRR v10.
eezypeazy
4 Jul 2005
The only problem I've encountered with BRR is on the Plymouth route... inexplicably, it doesn't like some of the platforms, and seems to discard them before you've passed them... obviously somehow managing to infringe the "25 metre" rule... don't have this problem running Plymouth without BRR...
Must admit, I'm using BRR less and less... and, on the rare occasions that I do run it, it's mainly to inflict signalling delays.... I always found the "route" randomising a little disconcerting - ending up running on the wrong road.....
And as regards changing trains, here's a little tip I picked up somewhere.... instead of having a different copy of each of your favourite routes with each of your favourite trains, simply put all of your trains in the "with Train" section, but comment out the ones you don't want ... er, or is that "comment in" the one you do...??? ... like this....
with Train
.Folder ONE_class156
;.Folder 37901 Empty Steel Carriers
;.Folder HST4
... then, before you open the route, just change to the train you want by swapping semicolons and saving the change to the file .....
If you were so inclined, you could also list different timetable bitmaps, and comment them in or out, too.... wouldn't change the stopping or timing pattern, but would simply display a correct timetable bitmap in the cab..
Regards
eezypeazy
The Snap
10 Jun 2005
I don't like the thing - I think it defeats the object of BVE. A route has been coded a certain way for a reason, so allowing people to modify it with fog and taking different routes is a bit...:silent:
Also, it doesn't work that well. It works well with changing trains, but when diverting a train along a different track it doesn't!
mbonwick
26 Oct 2006
Kendal
You all have valid points. As a matter of fact, I only use it to change trains!
Coxster
9 Jun 2005
You could then argue it's not always foggy at a particular time all the time ;)
Hence why you can turn the features you don't want off ;)
Boxcars
24 May 2006
Cambridge
I used to use it to do all sorts of things ;) when I first started using BVE but soon found that I was spoiling BVE's realism. When I say I think it's an essential part of BVE it's only because it makes it so quick and easy to change routes and trains. That's all I now use it for but I wouldn't be without it.
Guinness
13 Jun 2005
I find the Randomising Signals and Adhesions make BVE a lot more realistic. I agree with ending up on the 'Wrong Road' though.
eifion
2 Apr 2007
Hi Jordy.
I have just sent an e-mail to the one given on your southpte site and it has been returned as un-deliverable. It contained an attachement to download BRR10. Route Randomizer.
If you still need The Randomizer please send alternative e-mail contact.
Regards. Eifion.
Jordy
9 Jun 2005
WCML South
Hmm thats strange!
Can you try this one please (remove spaces)
j o r d a n . a l l e n 2 @ n t l w o r l d . c o m
Thanks alot!
Jordy
eifion
2 Apr 2007
Hmm thats strange!
Thanks alot!
Jordy
Hi Jordy. Just had another go at sending but having snags with B T Home Hub.
Hope it arrives.
niall
24 Dec 2007
Liverpool, UK
I use this every time I play, a GUI to change trains & routes is so useful, but I don't use any other of it's features...
