Bve "Needs to close"
shane252
24 Jul 2008
P4 2.66 ghz cpu
256Mb Nvidia N7600gs Graphics card
Windows Xp Home sp2 Net framework 2.0
Directx 9c
I had BVE about 6 years ago on my old computer so am familiar with the install etc, I have recently re-discovered it, what a great program! (when it runs)
Okay I downloaded Version 2 first and got some direct draw errors so gave up.
I removed the Version 2 and tried Version 4.
Now im getting Bve encountered a problem and needs to close error?
I have all of the lates drivers/Net framework etc, Ive even rolled back the drivers and completely removed and re-installed drivers but to no avail.
I have chosen different compatability settings too?
To me, as soon as I even try to run the program, after the display box, I get the needs to close error.
installed all Net frameworks available, I've also uninstalled the newest driver and installed the recomended old driver , still no Joy?
anybody's help would be appreciated
LondonBVE
22 Dec 2005
Lost!
Can you please tell us more about the error like the full error message or you can just put a screenshot. Alt + Print screen than open Paint or any image viewing program (Ie. Irfanview) and click Edit and Paste. Than save it and upload to any image hoster and post it here. :)
shane252
24 Jul 2008
Sorry, I'm jumping the gun as.
Okay I download and install Bve4 main program as per instructions, then unzip and install Uchibo10.
I click the Bve4 icon and a graphical interface option box pops up just before startup, I have selected the default full screen option, I then press okay and a microsoft error box pops up telling me that an error has occured and Bve needs to close.
When I try to right click the Bve 4 tab I don't have the compatability option either?
odd and annoying
6 year old PC? when was it last re-formatted?
It's probably a problem with .net framework.
I've known people throw away 3 year old PCs (not literally - recycle of course) and other people buy them for £10. There's no reason to use a PC that's that is old any more, unless it was VERY high spec at the time and has been heavily upgraded.
I've just got rid of my PC that was 6 years old this Summer but it was very high end at the time and 1 everything apart from the motherboard and case has been replaced. But the motherboard was slowing everything down so I ditched it.
shane252
24 Jul 2008
Sorry, the point I was making is that I knew how the Bve file structure/ install worked,.
I have a newer pc which i am constantly upgrading, it is this system that im having the probs with.
LondonBVE
22 Dec 2005
Lost!
Have you tried playing with Windowed mode? Oh and BVE 2/4 works with nVidia Geforce 7 series, the problem only comes in with GeForce 8, GeForce 9 and GeForce GTX.
jv3531
23 Jul 2008
Gloucestershire
May sound silly but try full screen with 1024 x 768. May be problem with graphics from objects. Not 100% sure but I can remember something along this line on mine, think it may have been the screen res that may have affected it, know its worked on some! Worth a try if nothing else....
shane252
24 Jul 2008
Yep thanks, had a play around with all compatability/resoloutions in the beggining tried again with those suggested but still not working.
I have looked at the registry and neither the Bve or Mackoy programs are there?
All other apps / Games are there but can't see these.mmmm
Could this be the problem?
jv3531
23 Jul 2008
Gloucestershire
May well be, may be worth just running the BVE install program again? Make a backup of your routes/objects sounds and trains folders and any others that you have made changes to just incase, run the installer and see what happens... If BVE setup asks to overwrite, reply yes to all as it won't re-install whats missing otherwise.
shane252
24 Jul 2008
Okay, thanks for all of the help so far.
I have un-Installed and re-installed/repaired Bve 4, It is still not in my registry?
Don't understand why, Do you know of any manual install option because this seems to be the issue.
