Is it possible to buy a GM Rail Ranger or a GM Bus & Train Daysaver outside Greater Manchester?
Yes. If all else fails ask a Guard outside the area to sell you one. If he can't find it on his Avantix machine, tell him to put "MAN" in the "FROM" field, and type "DAYSAVER" in the "TO" field. It will then ask him to select TB (Train and Bus), TM (Train and Metrolink) or TBM (Train, Bus and Metrolink).
Inside the area, Daysavers can be brought anywhere, including tram stops, from bus drivers etc. As a result there are that many different versions available there is no special ticket stock.
The Rail Ranger can be brought at any station or on train outside the area as well. On train, the Guard needs to go to Rover Enquiry and type in GM, and then select the relevant rover - day or evening.
