Bus fare 724
boiledbeans2
15 Oct 2020
Does anyone know the bus fare of route 724, if travelling from
- Heathrow to Watford
- Uxbridge to Watford
Are both at the £3 cap? I can't seem to find any fare info on their website.
Trying to compare if there is fare benefit in using TfL bus A10 to get from Heathrow to Uxbridge for option 2 above.
LA50041
20 Feb 2017
The Arriva website suggests that the fare Heathrow - Watford is £3
E B
30 Oct 2024
Nuneaton
An adult single for Route 724 is indeed £3.
boiledbeans2
15 Oct 2020
Thanks for your answers!
How is it determined which bus routes fall under the £3 cap? E.g., why isn't RA3 from Heathrow to Watford also part of the cap scheme?
JamesT
25 Feb 2015
https://www.gov.uk/guidance/3-national-bus-fare-cap lists routes that are and aren’t included. As it notes:
Participation in the bus fare cap scheme is voluntary and some bus companies have chosen not to take part.
Presumably for the RA buses they’ve decided the government funding isn’t sufficient to cover the shortfall and they’re unlikely to gain significant additional custom.
ChilliSauce
28 Oct 2025
I think there is a Red TfL bus from Uxbridge to Heathrow ....£1.75 single ???
There is certainly a Harrow-On-The-Hill to Heathrow Airport Direct Bus : SL9
Edvid
7 Feb 2008
With a few exceptions, the cap doesn't apply if you're on a coach.
Yes, the A10. Same fare on the Carousel 102 as well.
Neither will save you money for travel to/from Watford as Uxbridge - Watford is still £3 on the 724/725 anyway.
In theory you could connect with the 258 for a Hopper fare, but that's dependent on the timetables and traffic conditions.
Haywain
3 Feb 2013
Pretty unlikely with the SL9 scheduled to take 70 minutes from Heathrow to Harrow during most of the day.
stadler
5 Jun 2023
Horsley
Just to add to what others have said it is worth pointing out that the £3.00 single fare cap is valid on both the 724 and 725 buses. They both run along the Heathrow to Uxbridge to Watford route. They run hourly each and provide a combined half hourly service. So you can take either a 724 or 725 for the same journey time and the same £3.00 single fare cap.
boiledbeans2
15 Oct 2020
Many thanks for all your replies!
I had previously thought about the above as well. But what exactly is a coach?
E.g.
- Skills Motor Coaches states on the side of their ADL E200 "stylish coach travel [...]" https://www.alexander-dennis.com/al...ro400-double-deckers-at-skills-motor-coaches/
- Westway Coaches operating ADL E400: https://www.facebook.com/AlexanderD...le-deckers-to-westway-coach-/979164091084637/
- And this "executive" 10,000th ADL E400 interior: https://es5zyafq95u.exactdn.com/site-content/uploads/2023/06/ADL-Enviro400-milestone-3.jpg (main article: https://www.alexander-dennis.com/al...10000-bus-milestone-with-executive-enviro400/)
Statto
8 Feb 2011
At home or at the pub
Before the £3 fare cap, it was £10 single on the 724 to Heathrow (£20 return) because of the premium Heathrow charged, you could have bought an explorer ticket for £8, traveled to Uxbridge, then changed to the A10 for £1,75 single (which would be £3.50 if you're returning the same way).
Tetchytyke
12 Sep 2013
Isle of Man
Participation in the fares cap is voluntary. Operators will, generally, exclude their premium limited-stop or tourist services from the cap. Long-distance coach services are also excluded.
Operators will, generally, use coaches for these services. But a service being operated by a bus doesn't mean it is in the cap and a service being operated by a coach doesn't mean it is not in the cap.
The full list of routes is actually on the gov.uk website: https://www.gov.uk/guidance/3-national-bus-fare-cap
30 Oct 2019
GEML
Sorry if I'm missing anything obvious, but is this explorer ticket what is now the TravelEssex Saver? Or has it been withdrawn?
Edvid
7 Feb 2008
The Intalink Explorer (now labelled Intalink Connect All Zones) is a Hertfordshire ticket and still exists, but it's not valid between Maple Cross and Heathrow these days.
The Arriva-only All Zone* ticket is valid up to Uxbridge.
[* "All Zone" meaning Beds & Bucks + Herts & Essex, i.e. Shires & Essex as was]
stadler
5 Jun 2023
Horsley
It is worth pointing out that the validity was massively cut at the same time they changed it from the Intalink Explorer ticket to the Intalink Connect All Zones ticket. It is now only valid in Hertfordshire and on routes that go to and from Hertfordshire. But under the old Intalink Explorer it used to be valid all over the shires and on many operators routes that went nowhere near Hertfordshire. You could get as far as Chelmsford / Colchester / Braintree / Cambridge / Oxford / Bedford / Reading / Slough / Northampton / Brackley / Bicester / Banbury on the Intalink Explorer ticket. It is a shame it has so much less validity since it got changed a couple years ago.
boiledbeans2
15 Oct 2020
I tried this route 3 times so far, and yes indeed, the price is £3. I was doing Heathrow to Watford. Twice, the tickets was indeed printed Heathrow to Watford as the origin and destination (after I told the driver my destination). But the last trip, the destination was printed as Moneyhill Parade. I guess the driver just presses any button which produces £3.
Interesting. In that case, fares on this route has dropped significantly, considering when RA3 was introduced in 2023, it was £9, even cheaper than the former £10 for 724.
zero
3 Apr 2011
In 2012, I emailed Green Line and got the following reply:
Thank you for your Email.
An Adult Single from Heathrow Airport Central Bus Station to Rickmansworth Station (Stop C) is £6.40 and an Adult Day Return is £11.90.
Thank you
Greenline Customer Services
0844 801 7261
njr001
8 Feb 2013
To answer post #17 an ENCTS Bus pass is valid on the 724 I've used it between Heathrow & Rickmansworth on several occasions
boiledbeans2
15 Oct 2020
Interestingly, an advance (fixed time) ticket for RA3 on their website is also £3, even on the day of travel. Business must be bad...
Edvid
7 Feb 2008
If seats are available you can use any other service on the day of travel.
The BODS farechart on bustimes (First Hampshire BRA3) says £13 each way for adults so perhaps it's a web-only offer.
From Luton a bus journey to Heathrow requires a change at St Albans or Watford (2 x £3 singles) so I may well use the RA3 instead of the 724/725 on my next trip there...
benk1342
13 Jul 2011
North Herts
I did not know about bustimes.org! I think you have changed my life…
boiledbeans2
15 Oct 2020
Seems like RA3 is now £3 walkup. Both links in the above quotes have been updated. RA1 & RA2 are included in the first link, but not the second.
Edvid
7 Feb 2008
Rode on the RA3 last Wednesday and upon leaving Heathrow around noon it was still very quiet despite the low fares. If that's typical of the route in general it won't last the rest of the year.
With regard to routes that serve Terminals 2 & 3 specifically (as opposed to the Central Bus Station), a RailAir return to Watford is now cheaper than a Hotel Hoppa single!!
