Bus company scam ?
Been waiting at the bus station for the half hourly bus run by a well known bus provider.
The display says that the bus is due but no sign of any bus. Speak to metro who say that the bus is two minutes away, yet ten minutes later still no sign of the phantom bus.
The bus isn't showing as cancelled and instead just appears as "due" until the next bus is due.
Is this some sort of scam to avoid telling the metro authorities that they're not running the service promised ?
GusB
Elginshire
Which company is it?
K4016td
18 Dec 2012
Slough
I'd say that in this situation the display is not showing actual arrivals and departures based on GPS-tracking but on hard embed timetable that's programmed into the system.
cactustwirly
10 Apr 2013
Most likely the bus is stuck in traffic and the metro system hasn't updated or can't track the bus.
You can track the bus on the companies app, if it's a bigger operator.
Normally it gives the time expected when that happens.
Maybe that's it.
Roger1973
5 Jul 2020
Berkshire
Yes, normally if a bus isn't running at all (or if it is running but for whatever reason it's not tracking properly) real time displays will show the scheduled departure time (as a time rather than number of minutes) until that departure time has passed.
Some systems allow operators to intervene and put 'cancelled' up if they know a journey is cancelled, but not all local authorities give operators access to do this, not all operators have the staff resources and inclination to do this.
(I don't know West Yorkshire very well at all, so have no idea just what system/s are in use there or what the local policy / practice is.)
A bus appearing 'stuck' a number of minutes away suggests that the 'stuck in traffic' situation or possibly breakdown on route is more likely. The system isn't a crystal ball - it will assume that if a bus is X distance away, then it should normally take Y minutes (at that time of day) to get to this stop, and it won't know whether the bus is just at a bus stop or whether something else has happened.
I suppose it would be feasible for a system to show something else if a bus doesn't move at all for X amount of time (some of the displays on the railways will change to 'delayed' if the train stops for too long) but I've not met that on bus RTPI displays.
Likewise, the system will assume that if a bus is approaching a terminus and isn't so late that it won't be able to leave on time, that it will leave on time. The system won't know if there's a driver change-over scheduled and / or if the driver who's supposed to take over isn't there.
The other possibility might be if the bus has gone off-route for whatever reason and isn't serving that stop. The systems are supposed to work so that a bus 'clears down' from the display at a stop once it's gone past. This can occasionally go wrong, and it can get confused if a bus is on diversion, and a diversion timetable / stop blocking hasn't been entered in to the system.
Although in this case, I'd have thought that if there was a diversion away from somewhere like a bus station, then there would be some form of information out there unless it's something that's happened very unexpectedly (like a sudden major road failure or police have closed the road for an incident.)
If you want to put a complaint in, Metro and / or the operator probably have the ability to see the tracking data for that route / journey and see where the bus actually went and when.
richw
10 Jun 2010
Liskeard
From the symptoms described. The bus is stationary nearby, broken down, parked with no driver, stuck in stationary traffic.
The key is that from the info given the bus is live tracking not far away.
GusB
Elginshire
We've got an ongoing discussion about bus stop information displays, so this one will be locked to avoid duplication.
