Burscough curves turned down
Djgr
30 Jul 2018
According to the Liverpool Echo today (https://www.liverpoolecho.co.uk/news/liverpool-news/people-town-isolated-after-rail-22246101) people in a town (i.e. Southport) are to be isolated after rail link plans rejected (i.e Burscough curves).
Lots of unsympathetic comments left.
Burscough Curves were two sections of rail track which connected the Southport to Burscough train line with Preston, Ormskirk and Liverpool.
The line was axed in the 1960s, with plans drawn up and submitted to the government this year to rebuild the rail line.
The link would have allowed people to commute directly to Preston and Ormskirk without having to change stations or lines.
The Department of Transport made the decision to turn down the application for £50,000 of funding to further look into feasibility studies.
This always seemed to me to be a solution looking for a problem.
It's not really. It would, done right, improve connectivity by rail around West Lancashire substantially, as well as saving a unit and crew on the Preston service (as you can do hourly Preston-Burscough and back with one rather than the present two) and extending Merseyrail to Burscough which is on the edge of the Liverpool commuter area (which is to me a better fit than sending it all the way to Preston). And all for about 3 miles of track, a bit of signalling and one rebuilt station.
I guess it's hard to set against the others because it's a connectivity improvement rather than anywhere new getting a service that didn't have one before.
The story is odd, though, because it doesn't really affect Southport that much.
4-SUB 4732
7 Jan 2018
I agree with solution looking for a problem, or a white elephant.
We are all desperate to focus on a reliable half-hourly service north of Kirkby to Wigan Wallgate, and a half-hourly service north of Ormskirk to Preston. Both would be a fantastic and genuinely revolutionary change in the region.
That Southport felt they needed a service to Preston and to Liverpool via Ormskirk (isn’t a quarter-hourly service via Hall Road good enough? Few people elsewhere in the North get such a good service) is hardly surprising, however. This is a group of residents of quite small importance who somehow got to ruin a timetable and service for an entire region just to be able to go to Oxford Road without changing trains on the very same platform at Salford...
I doubt Southport residents particularly care about trains to Ormskirk. Given the relative importance of the two towns it is almost certainly the other way round.
Half hourly Ormskirk-Preston would certainly provide most of the benefits, but would cost a lot more as it'd require about 15 miles of redoubling. The advantage of the Curves is that it would provide some quite big connectivity gains while it would save some operational money e.g. reducing the number of units required to operate Ormskirk-Preston from 2 to 1. (The interworking with Colne thing was a disaster, and so while they do still interwork a unit and crew was added into the circuit, meaning the same number as if the lines operated separately).
Starmill
18 May 2012
Bolton
In the specific case of Preston to Southport why does it not seem legitimate to suggest that better public transport is a reasonable demand? It's only 20 miles but can't be done in under 55 minutes. There's only one direct bus per hour. That's pretty rubbish.
If it can only sustain one bus an hour, is it really a bulk public transport flow?
Starmill
18 May 2012
Bolton
Same could be said of most public transport in the whole of England (excluding Greater London). Public transport fundamentally requires some level of public subsidy to operate, but we've had most of ours stripped bare. The demand is all sitting in the traffic congestion in the area.
Not really bothering to even try to connect a large town and a small city which are less than 20 miles apart with a service slightly better than the X2 or a train changing in Wigan (taking typically 60 - 70 minutes) is outrageous. But it has been totally normalised in England.
It's not just about one flow. It's a connectivity gain even if you add no services. Ormskirk (and the north end of Merseyrail) to Southport, Wigan and Manchester plus Southport to Preston, and it can be done at the cost of one additional unit and crew*, three miles of track, some signalling, a reversing siding at Ormskirk and one station rebuild.
* Reduction of one on Ormskirk-Preston (hourly service to Burscough is possible with one unit/crew), gain of 2 on the Ormskirk-Liverpool circuit (for a half-hourly service to Burscough with the line remaining single you'd have to have a unit stay at Ormskirk for half an hour between the one going to Burscough and back, I worked the timetable out years ago). No additional units and crew overall if you redoubled Ormskirk to Burscough. Two more units/crews if you wanted to run Merseyrail through to Southport on batteries half-hourly, and one more for a Southport-Preston rather than Burscough-Preston DMU, but you'd still get a lot of the benefit without those.
4-SUB 4732
7 Jan 2018
On balance, if you include signalling changes, one assumes building two curves and then still having to do whatever (electrification west of Burscough?), it would be cheaper than putting in the half-hourly Preston and half-hourly Wigan services. The reality is that Southport to Ormskirk and Southport to Preston are very achievable by bus, and focus should be on a 20-minutely (or so) service on both.
And by abandoning the curves, and focusing on direct Preston half-hourly, you could close the existing two stations and open an interchange a bit like Tamworth with good parking and such, and then people could change. It’s better that way for all concerned.
Quite.
Bertie the bus
15 Aug 2014
It very much falls into the same category as Skipton - Colne. Of very little use to anybody but a very vocal supporting group who just won't quit. Just because the track bed of the curves remains intact doesn't mean there is a case to relay them.
4-SUB 4732
7 Jan 2018
Also big agree.
Moving the station to the crossover is an interesting idea and could I guess be done in conjunction with housing development. You would want a pedestrian/cycle route from the new station to the Junction area, though, as it is a bit of a long way round as it is.
Opening Mill Dam Lane (proposed in the 70s) would also make sense.
507020
23 May 2021
Southport
What is all this about 3 miles of track and a rebuilt station? The Burscough Curves are 66 chains of single track, that is less than 1 mile and all present stations can stay as they are. With the exceptions of Ormskirk and Burscough Junction where the 2nd platforms should be reopened, which is as much redoubling as just about amounts to 3 miles of new track. You wouldn’t have any DMUs on an even more truncated Preston - Burscough service because the 777s from Ormskirk and Southport would run through, requiring a few more of those but freeing up a few Sprinters. Quite a bit of signalling needs doing between Southport and Burscough Junction because there is no resiliency at present, or capacity for more services.
Is Wigan Wallgate not East of Kirkby? Of course by reopening the Burscough Curves, 4tph from Liverpool Central to Ormskirk can run through, half to Southport and half to Preston, as well as 2tph from Southport to Preston (some of which should continue to either Blackpool or Windermere) which is truly a new service. Surely this is transformative to rural communities as it gives 4tph from Rufford and Croston (and Midge Hall if reopened) to Preston and 6tph from Southport to Burscough Bridge, with more trains running through New Lane and Bescar Lane and to more destinations, giving more public transport options to the people who would otherwise be the most isolated, but the services remain viable because they directly serve 350000 people in major population centres.
And no 4tph via Hall Road is not good enough when there is a trespasser on the line at Seaforth several days in a row and no service is running at all. Surely a diversionary route via Ormskirk is a good idea and dare I suggest that any of the 90000 people who live in Southport might ever want to go to Aughton, Maghull, Aintree or Walton?
Why exactly are the residents of Southport, the 13th largest town in the North West (and also Formby, Hightown and Crosby who may change at Southport if they wish to go to Manchester) receiving 100% of the blame for “ruining” a timetable when this was caused by too many trains running through Castlefield from other places (e.g. Chester, Sheffield and other places which are accessible from the main shed at Piccadilly) and in any case it would be a vastly better experience to change at Bolton than Salford Crescent.
If the objection is to running Sprinters through Castlefield, then the problem is that the line to Southport has not been upgraded to allow 195s to run, not that people from Southport want to make a perfectly reasonable direct journey to Oxford Road, Piccadilly or Manchester Airport, which was possible for 20 or 30 years.
I particularly care about direct services to Ormskirk, as I’m sure all other residents of Southport with a need to travel to Ormskirk hospital and vice versa do. I went there yesterday on the bus for the first time in a while and after 20 minutes had passed since I left Eastbank Street I noticed that I still wasn’t anywhere near half way there but was stuck behind a tractor.
I don’t know who can seriously suggest buses as a reliable way to get from Southport to either Ormskirk, Preston or Aintree when the road infrastructure simply doesn’t permit a reasonable journey time and all but 66 chains of the required rail infrastructure is sitting there almost unused.
Interworking with Colne services did disastrously compromise the timekeeping of Ormskirk - Preston services, which is why they should interwork with Ormskirk - Liverpool services instead. I note that there is still 1 train a day at peak time which still runs from Colne to Ormskirk.
I believe there are 2 direct buses an hour, but you are right in that it can’ never be done by road in under 55 minutes, while quite often it can only be done in well over 55 minutes, with the buses frequently 25 minutes late from Liverpool which straight away makes it 80 minutes.
Except for the demand which is suppressed in journeys which are not attempted in order to avoid sitting in said traffic congestion. Southport is actually closer to Preston than Blackpool or Ormskirk and yet it takes over twice as long to get there.
How has it taken them a month to find this out?
Because it’s not news. It’s not even true that they’ve been rejected. The line to Okehampton has just reopened without funding from the Restoring Your Railway fund and note that there is no requirement to change at Crediton and wait for the next train from Barnstaple to Exeter!
Putting on an extra bus an hour only reduces the journey time if you include the wait by 10 minutes and if you don’t include the wait then not at all. What a waste of time thinking about.
The Burscough Curves very much fall into the same category as Colne - Skipton in that there was no case for lifting the track in the first place because they form a vital through route between significantly sized towns and the rural communities in between. In fact they could be reopened in conjunction with each other and you could run a through service from Southport to Skipton. I believe a Stagecoach bus did this once. Then the focus can shift to extending it to Ripon via Otley.
Isolated? How?
It is certainly true that the application via Restoring Your Railway is not being taken forward. You might not consider that as ‘rejected’, but I suspect most people will.
Okehampton received over £40m from the Restoring Your Railway fund.
507020
23 May 2021
Southport
It received over £40 from the government independently of Restoring Your Railway under Project SPEED. It was not included in any of the 3 phases of the Restoring Your Railway but since it has reopened the government has been promoting the Restoring Your Railway fund saying that this is what will happen elsewhere.
I find that schemes that were not included in the Restoring Your Railway fund are the most likely to reopen e.g. the Burscough Curves, Colne - Skipton, Portishead and that these will likely receive some degree of local funding.
Xenophon PCDGS
17 Apr 2011
What is the level of car ownership in the area under discussion? Not everyone is enamoured of public transport to the same extent as the Mayors of Liverpool and of Greater Manchester,
It hardly takes much crayon to work out the best way to reopen the Burscough Curves!
You miss my point. The crayonistas see those curves as only part of "the great rail leap forward" with new lines hither and thither.
Starmill
18 May 2012
Bolton
Public transport is very poor in those areas also, it's just that it's better than in West Lancashire, where it's barely usable. Most people everywhere in England except for London just drive for local travel.
That isn't totally true - Merseyrail is well used for local journeys as it's rather good.
507020
23 May 2021
Southport
What is the level of car ownership in the area under discussion? Not everyone is enamoured of public transport to the same extent as the Mayors of Liverpool and of Greater Manchester.
The question of car ownership I believe becomes irrelevant once it becomes faster to make a journey by rail than by car. The journey from Southport to Burscough Bridge already is.
I still don’t see your point I’m afraid, because the first of these lines has opened already, forming the first phase of the new diversionary through route from Exeter to Plymouth.
Last week I saw not 1 but 2 people board the 47 (at its new reduced frequency) in Southport and ask for the Riverside caravan park in Banks, West Lancashire, only to be told that it hasn’t gone that far since 2014. Why is West Lancashire always losing out when it comes to public transport?
I think it follows that the only reason Merseyrail is used at all is that it’s service is usable, which the Burscough Curves in their present state are not (and neither are the roads from Southport to Ormskirk or Preston).
Starmill
18 May 2012
Bolton
It's all relative. The bus and tram network in Nottingham and the Tyne & Wear Metro are also very well used, but it doesn't mean they're fit for the region by international standards.
It's a textbook S-Bahn. Certainly meets German standards (better in some ways), though its coverage is a little patchy.
The TW Metro is an U-Bahn on precisely the German model, nowt wrong with it.
I can assure you:
1) the Okehampton line reopening has come from the Restoring Your Railway (RYR) budget.
2) Project SPEED has no budget - it is a process change.
3) If a reopening project is not accepted into the RYR Programme, which for the avoidance of doubt includes the previously announced ‘advanced proposals’ (such as Skipton - Colne, Fleetwood, etc) then it will not receive Government funding or support.
4) Burscough Curves applied for RYR funding - twice. It has not been successful in either attempt.
5) if Burscough curves are to happen, it will need a different source of funding.
6) a proposal being successful at this stage of RYR does not mean it will be built. I’d be surprised if more than a third even make it to the next stage.
I grew up in the area and like the Tube people do use Merseyrail (like the Tube) sort of by default if it is applicable to a given journey despite the very high car ownership in places like Ormskirk.
I don't doubt that (the hospital aside as it's nowhere near the centre) people from Ormskirk would go to Southport by train by default if Merseyrail operated a less roundabout service. Some people even do use it via Sandhills in preference to the bus.
Starmill
18 May 2012
Bolton
But without the coverage, or the connections. Merseyrail aren't returning to quarter hourly service just yet either.
This is off topic here however.
