burngullow ecc
Finners12
26 Aug 2024
Bodmin
Is the burngullow ecc sidings before or after lanjeth crossing. im looking to spot a freight at lanjeth crossing
Gloster
4 Sep 2020
Up the creek
Burngullow is the actual junction on the main line and Lanjeth is about a mile along the branch to Parkandillack.
Mcr Warrior
8 Jan 2009
Is the OP likely to see much at Lanjeth open crossing? Can only see the one daily working scheduled from Burngullow Junction on to (and then back off again) the Parkandillack branch line. And that only seems to run "as required". Presume it's china clay that's being hauled?
Finners12
26 Aug 2024
Bodmin
Is the OP likely to see much at Lanjeth open crossing? Can only see the one daily working scheduled from Burngullow Junction on to (and then back off again) the Parkanddillack branch line. And that only seems to run "as required". Presume it's china clay that's being hauled?
more then 7 freight trains are seen on the line today. British lithium mining has begun in the clay pits
i would also like to know if goonbarrow is on that line
Nottingham59
10 Dec 2019
Realtime trains will show what trains are in the timetable. Note that lots of trains will appear in the timetable, but won't actually run. Entries need to be activated first, and you can only be sure a train is running when you see it has departed its origin.
Goonbarrow is on the line between Par and Newquay.
Have a look at openrailwaymap. you can zoom in to see every detail of the line
If you have any more questions, do feel free to post them here and we'll try to help
Freightmaster
Verified Rep
7 Jul 2009
Realtime trains will show what trains are in the timetable. Note that lots of trains will appear in the timetable, but won't actually run...
I try to avoid shameless self promotion because I know it irritates some people,
but the above is exactly why Freightmaster exists and is still going strong after
30 (yes 30! o_O ) years...
MARK
