British Rail sign inside tube station
Lewlew
15 Oct 2019
The ones on the platforms at Marylebone have recently been covered up with stickers saying “National Rail”
27 May 2021
Daventry
I Believe there is still something similar at Greenford pointing passengers towards the bay platform for the West Ealing Shuttle...
Recessio
4 Aug 2019
Vauxhall LU, I believe? Interesting that a sign has been out of date for so long that it has now with GBR become correct again!
Semi-related, the Central line "sonya" announcements still referred to changing for Network Southeast (the Waterloo & City) services at Bank for years after the transfer to LUL, up until their next refurbishment.
boiledbeans2
15 Oct 2020
There are a lot of old maps around, especially in Central London tube stations - the large map on the curved track wall. I can't remember where, but I remembered seeing the old 1980s DLR logo on one of the maps, and of course a lot of BR (Bank W&C platforms have the 1990s DLR logo). I remember some maps still refer to the H&C as the Met.
Liverpool Street Central Line has a map at the bottom of the escalators with Epping - Ongar covered up.
Edit: after checking some online photos, the Liverpool Street Central Line map is the one with the 1980s DLR logo.
Edit 2: which... no longer exists at Liverpool Street.... Probably removed when Crossrail opened.
321over360
17 Jul 2015
It did with Stratford and Liverpool Street too until the 2000s, as they were still doing "This is Stratford, Change for Docklands Light Railway and Network SouthEast services" until the milenium if i recall correctly, same with Liverpool Street which prevailed as "This is Liverpool St, Change for Metropolitan, Hammersmith & City and Circle Lines, Network SouthEast and Intercity Services" for many a year post privatisation.
I think there is a map at Newbury Park which still has the Epping to Ongar branch covered up behind a sticker. Most of Central Line has been updated with stickers cos its cheaper than full maps, as im sure once Bond Street Crossrail platforms opens they will just update the carriage maps with a small sticker rather than using new maps given it makes more sense less hassle and is far cheaper to do,
NSE
3 Mar 2010
and signs for Bristol at Clapham Junction platform
There’s loads of old and out of date signage or evidence of signage around the network. The down fast SWML still shows Penzance, Plymouth and other west of Exeter stations on the list at the top of the staircase that SWT stopped serving since before they became SWR.
Things get stickered over when changes happen so it’s quite common to see evidence of what was there before.
Mojo
7 Aug 2005
There appears to have been a change of policy of late whereby entire new car line diagrams are being produced rather than individual stickers that go over stations or groups of stations, even for relatively short-term things, such as the Bank blockade on the Northern line earlier this year, and on the Jubilee and Central lines where Crossrail interchange at Bond Street is shown as crossed through.
0nlySam
1 Sep 2014
Similarly, the Aldwych branch is visible on the Piccadilly line map on the eastbound platform at Baron's Court, as the presumably 28-year old sticker is peeling off.
boiledbeans2
15 Oct 2020
Maybe it would have been better to produce the "final" Central Line map showing the interchange at Bond Street. Then cover it with a sticker for the time being. When the Bond Street interchange eventually opens, peel off the sticker to reveal the clean final map.
Vespa
20 Dec 2019
Merseyside
Is it still there ? I've not noticed myself, is there a photo ?
0nlySam
1 Sep 2014
"Barely visible" would admittedly be more accurate, but you can definitely see it at least ;)
Vespa
20 Dec 2019
Merseyside
Thanks, that's fascinating, I remember riding it just before it closed, if I recall I went through a side portal at Holborn to go to Aldwych.
