Dai Corner
- Joined
- 20 Jul 2015
- Messages
- 6,990
Let's hope they overestimated the height, or at least left plenty of slack in the cables!I’m not joking![]()
I'm positive early OLE feasibility design was used to design the modular construction of the new gantry to ensure compatibility for future electrification. The current construction may not provide full compliance in its current configuration but its designed for OLE to run through there.I’m not joking![]()
I was under the impression that all new work had to be compliant with electrification standards. The new East gantry certainly looks high enough.Unfortunately that nice new signal gantry may not be fully compatible. Apparently they had to guess, as the OHL design has not been completed yet…
Thinking on electrification and signalling is evolving somewhat (certainly in other regions) with more recent designs LED signal heads that are much small and lighter; and the assumption is that many will need minimal attention till replacement. e.g. signal heads on pivoted arms that can be lifted up to the gantry for work if needed so no need for bulky cages etc. or go for line block and turn the juice off.As I understand it, the problem is that without a finished OHL design, the ‘drop down’ sections where the signals are located and the staff protection ’cage work’ may need to be altered. The height of the main structure should be okay.
This is not the first time that new signal heads or signal structures have had to be altered or replaced soon after being brought into use, as they no longer meet the required minimum clearance distances. This affected various signals in the Bristol Parkway area when the OHL was installed there.
Often the problem is not that the trains can physically pass. But that the distance between a live pantograph (any part of it) and either the ‘cage’ or a worker on the signal may not meet the minimum distance required in the standard.
Are they using those on the gantry at TM or something more traditional?Thinking on electrification and signalling is evolving somewhat (certainly in other regions) with more recent designs LED signal heads that are much small and lighter; and the assumption is that many will need minimal attention till replacement. e.g. signal heads on pivoted arms that can be lifted up to the gantry for work if needed so no need for bulky cages etc. or go for line block and turn the juice off.
edit to add: e.g. these east of Manchester Victoria:
Its fun!Wot no buddleja?
Yes it looks good, and drivers already taking advantage of the quicker starts from P3 to the up Filton Relief..
Guessing that's to do with it all being fairly new and the air temp today expected to be mid-high 20s, translating to a track temp in the 40s
