Bristol Airport access
Tomos y Tanc
1 Jul 2019
Yeah in my experience there isn't a huge difference between Cardiff and Bristol airport and the London airports amazingly.
Can take 2 hours in traffic driving to Bristol airport from Cardiff, unless you are doing it very late at night or early morning. Train to paddington then to Gatwick/Heathrow/Luton is not a huge amount more than 2 hours.
True enough, if cost isn't a factor.
Trains are expensive and since Heathrow mainly caters for full-service carriers, you need to get to Luton, Gatwick or (heaven forefend) Stanstead to access low-cost options.
Personally, for holiday travel, I just tend to see what's available from Cardiff and book accordingly. The real problem comes with business or short-break travel where there are no good options from south Wales.
Topological
20 Feb 2023
Swansea
It really depends where you are going. Most of my destinations need long haul so aside from KLM at Cardiff, or KLM and Air France at Bristol, I am always looking at Birmingham/Manchester or Heathrow. Heathrow then becomes my most common choice. Gatwick does have some good options for America as well.
I got some good advances to Stansted and then the actual journey by rail is smooth enough thanks to the Elizabeth Line. Likewise, Gatwick with a change at Farringdon, or with a change at Reading is doable. Luton also has the Farringdon option.
For most the relevant comparisons involve driving and parking. The M4 makes Heathrow by car easy. Though the M25 is not great, Luton and Gatwick come within sensible drives as well. Stansted is the wrong side of London, but is doable. Combining driving the M4 to West London and then Elizabeth Line / Underground options brings all the airports with lower cost options into reach too.
Smwrff
27 Dec 2023
Cymru Fawr
I think that Cardiff could do with an 'airbridge' to Stansted. 2 or 3 regular daily flights run by Ryanair to connect to thrir European network there.
The exile
31 Mar 2010
Somerset
All such short hop flights should be banned on environmental grounds (other than island hoppers).
Cross City
27 Jan 2020
Ryanair don't offer connecting tickets, never have and likely never will. So even if this did happen having bookings on separate tickets means that if something goes wrong on one flight then you're left high and dry should you miss onward connections.
Ryanair wouldn't mind.
mrmartin
17 Dec 2012
Gatwick and Luton aren't bad to access - 1 change at farringdon with full step free access.
Also, Gatwick and Luton are often cheaper for popular destinations than Bristol in my experience, which makes it a bit of a toss up in terms of cost. You can usually get cheap advances at least on the way there as you tend to book flights far out. Plus there are usually way more flight time options, meaning you don't have to get up at 4am.
