Brighton to Beverley for Xmas
matt9f
11 Dec 2013
Hi all, can anyone suggest any splits etc for this journey, probably weekend to weekend? I have a Network card and have been looking at London Midland only Euston towards Derby. Failing that, if I pay out for an open return, are there any off beat routes I can take? I've done the EC/MML to death...
Welcome to the forum.
For a long distance journey via London, if you want a 'walk-up' ticket that does not tie you to a specific train (I'll avoid the term "open" as that term can have different meanings), then unless you are happy to take (much) slower routes, it's generally best not to split.
If you wish to use LM, you could split at London & Sheffield, making use of the LM & XC Super Off Peak Return from London to Sheffield (change at Tamworth or Birmingham).
If you are happy to be tied to specific trains, you may be best with a EC & Connections through ticket. The cheapest fares will have gone many weeks ago though, and the lowest tiers are not available south of King's Cross, nor are Hull Trains & Connections (but Southern do cheap Advance fares from Brighton to Victoria).
If you buy a through ticket, such as the Super Off Peak Return, you may take any permitted route, which would allow you to travel out of Liverpool Street, via Cambridge, if you want something "off beat". You could even go via Lincoln, but if you want to cover that track, I'd wait until the next EC diversions personally!
matt9f
11 Dec 2013
Thanks for the reply. As usual I've missed the best advances but like flexibilty and am happy to write a day off exploring and not be tied to specific trains. The London Midland super off peak does look good value. Would the via Cambridge route be valid through Ely or just Huntingdon?
Oscar
Fares Advisor
11 Feb 2010
Switzerland
Yes, the ticket is valid via Cambridge and Ely on Map AH of the National Routeing Guide (Brighton Group to Hull Routeing Point is given as valid via "LONDON" in Section C i.e. any route valid for Brighton to London and for London to Hull - map AH covers London - Ely - Peterborough - Hull). Huntingdon is on the East Coast Mainline south of Peterborough and you can't travel Liverpool Street - Cambridge - Stevenage - Peterborough using this ticket. The Midland Mainline is, however, a Permitted Route using map SY. See Rail UK Fares and Ticketing Guide - Section 3 - Routeing for a detailed explanation of how to use the Routeing Guide.
Harpers Tate
10 May 2013
I don't know whether this is of any interest, but I gather that Hull Trains are operating to St Pancras via the MML (using the Sheffield avoiding line between Rotherham Masboro and Chesterfield) on Friday 27th (only).
bb21
Emeritus Moderator
4 Feb 2010
Only two return journeys and likely to be extremely busy.
