Brief problems across South East tonight?
Saint66
15 Dec 2013
Herts
There's a few reports that a power surge on the national grid across the South East has impacted several lines into London due to signalling and OHLE being affected.
FCC have one or two delays it seems? While South Eastern had their signalling go down for a few minutes?
A few tube line's are also reporting power supply problems it seems (I know this is the rail forum, but it seemed to add to the context, apologies!)
Anyone else heard anything, or have any updates?
Excuse the awful spelling mistake in the title!
user15681
3 Jun 2012
This does seem to be the case. I must admit, my lights did go off and then come back on, along with my TV, a little while ago, probably 30-40 minutes, maybe more. I've seen a picture of a lot of the lights out at Waterloo station.
It affected a significant area, although delays are specifically prominent in the London Bridge, Wimbledon, Streatham and Blackfriars.
Note this seems to be a National Grid problem and not something necessarily to do with Network Rail or TfL infrastructure. Lots of lifts stuck, lights coming on at film premieres and street lights out across south London tonight.
Yep a Grid problem. Knocked out signalling briefly across most of the south east.
Also made my lights dim in deepest Hertfordshire. :idea::idea:
Nevertheless, in train delay terms, it's Network Rail's fault. ;)
jon0844
1 Feb 2009
It's the energy companies wanting to make a point about the problems we'll all face if they aren't allowed to keep increasing prices!
Saint66
15 Dec 2013
Herts
I was just quite shocked by how wide a region it affected! Lucky it didn't happen any earlier when lines would've been much busier.
We had our lights flicker here in Herts, and it's still affecting FCC services now.
Interestingly, it sounds like a lot of lights in public areas, such as stations, and street lights etc still haven't come back on.
RichmondCommu
23 Feb 2010
Richmond, London
Yes we noticed it here in SW London. Thanks for posting this by the way.
Saint66
15 Dec 2013
Herts
NRE service alteration notice: 'Delays to services in the South of England until further notice'
At least they're honest! :D
Peter Mugridge
8 Apr 2010
Epsom
Yes, had this in Epsom - about ½ way through the BBC News at 22.00 the lights and TV flickered off for a second or so.
user15681
3 Jun 2012
Actually, on this subject, I had the exact same happen in the early hours of Saturday (29/03) morning, around 0200. Now that would have gone unnoticed to most as most are in bed, trains aren't running etc. Were any similar problems reported then?
Daniel
5 Oct 2005
It was broadcast over my line channel, stating a number of stations having blackouts owing to UKPN supply issues - apparently a blackout lasting around 5 minutes. Didn't affect service control on the met line at least. I did notice the Bakerloo, District and Victoria lines all had partial suspensions for a time owing to the supply interruption, for a time.
20 May 2009
Bromley
I was travelling through Lewisham when this happened. Train was sitting at the platform, and just at about 22:20, the platforms were suddenly plunged into darkness. The service was delayed by about 10 minutes whilst they waited for the power to come back on.
user15681
3 Jun 2012
I should imagine it was a tricky night for those control rooms affected!
The Bakerloo was suspended Lambeth to Elephant, Victoria was from Stockwell to Brixton and District was around Richmond area. Overground was also suspended from Richmond to Willesden. Sort of gives a rough idea of the area effected.
UKPN have since denied any fault on their behalf, blaming National Grid.
Lockwood
4 Apr 2013
What happened to the good old days when the railway infrastructure had its own power supply?
Blindtraveler
28 Feb 2011
very true. On a serius note, hope no too many foalk were stuck in lifts for long, it can be scary.↲
Be3G
14 Sep 2012
Chingford
Ah! So that's why our lights flickered briefly in North London last night – the power didn't go out long enough to cause any electronic devices to actually switch off. The electrics in this flat aren't great so at the time I just put it down to a random glitch.
otomous
5 Oct 2011
I believe the mainline railway has always drawn its traction power from the grid. The London Underground generated its own until 2002 I think.
trainfanatic
4 Jan 2010
Big Sky Country - Sleaford
That would be a Power Station sited at Chelsea waterfront (can't quite recall the name of the station) generating power for London Underground. I worked there briefly many years ago.
Enhanced post
user15681
3 Jun 2012
Enhanced post
Lots Road, was it?
Mojo
7 Aug 2005
Apparently was caused by National Grid routine switching at Beddington.
(Awaits Nym to come along and explain what this means)
Saint66
15 Dec 2013
Herts
I'm surprised that an issue at one substation (as mentioned by National Grid on Twitter) affected such a big area?!
user15681
3 Jun 2012
As is always the case, a localised problem on the railway can spread far quite quickly. The substation is by no means small, either, and feeds the surrounding areas, particularly Croydon, Wimbledon, Staines and Brixton areas.
Saint66
15 Dec 2013
Herts
But it affected signalling on the South Eastern routes (into areas like Kent) and also caused my power to go off and back on here in Herts, along with affecting FCC services up here! :o
user15681
3 Jun 2012
Like I said, it's a pretty big substation and feeds a lot of south London, I believe. I'd put the SE problems into Kent from Victoria down to this, given that the substation supplies Brixton and the surrounding areas. Hence why Victoria line Brixton to Stockwell, Bakerloo from Elephant to Lambeth and SE heading out of Victoria were affected (not sure why London Bridge was, but can only assume it's linked in there somewhere). As for the problems in Herts, I can't explain that. :|
Class377/5
19 Jun 2010
It caused a surge in the linked systems that saw SWT, C2C, FCC among others hit.
hassaanhc
5 Jan 2014
Southall
No idea exactly what happened but with the types of bulbs that many floodlights/streetlights and the like use, if switched off then they won't switch on again until they've cooled down a bit. Or was it a proper outage?
Just before 2000 I was on the Emirates Air-Line cable car, while afterwards I was at North Greenwich Bus Station and around 2030 onwards on the DLR from Woolwich Arsenal, and I didn't notice anything. Mind you, a few years ago a few power surges days apart damaged the RAM and motherboard on my dad's PC :( (well they still worked until we unassembled parts a few days later to clean out the dust :lol:).
