Bridge Strikes
richw
10 Jun 2010
Liskeard
Bridge strike at Tulse Hill today, via @internetben on twitter:
COc9tx0WgAA7lKs.jpg:large
https://twitter.com/InternetBen/status/641549345918197760
Notable that this one of the bridges at the top of NR's list. What more can be done to protect it?
That one is only an inch or two too high. Measurement issue either truck or bridge? Road being resurfaced could make a few inches difference,
Haydn1971
11 Dec 2012
Sheffield
My solution has always been simple - heavy gauge steel portal each side of low bridges and a huge fine for anyone hitting the portal to fund more portals - signing is all well and good, but no bugger looks at them.
james60059
6 Jul 2006
Hinckley
I've noticed in the last year or so, the railway bridge over the A5 at Hinckley now has steel beams either side of the bridge to protect the structure, as well as large display boards to alert drivers if their vehicles are too high. And yes looking at the beams, they have been struck anyway :roll:
peterinsurrey
31 Mar 2009
knowing this location very very well, what they actually need to do is reduce the height of the bridge if it's not going to get any higher. 4.2m is just enough for the truckers to give it a go. I see a truck sneak slowly under it every time I walk under it.
A quote I found on a truckers forum: "That one at tulse hill though is at least 3" higher than stated, i dont know how much higher as i had my eyes shut at the time !".
Put a solid bar underneath & they'll stay away...
hwl
5 Feb 2012
Repairs at tulse hill currently underway with some of the diagonal cross bracing between the pillars being replaced.
21 May 2014
Here's an idea. How about a sign that says "20 HGVs HIT THIS BRIDGE LAST YEAR." They could try putting it on that dot matrix sign ahead of it.
Perhaps *then* the drivers would give it a second thought?
Antman
3 May 2013
I don't understand why anybody would want to "give it a go" when there is an easy route around the bridge.
If that container lorry had been a bit higher the impact could well have caused it to overturn.
M7R
15 Sep 2010
That's a high cube container, you can tell by the code on it and the chevrons in the corners to warn its higher than the normal (9ft 6 vs 8ft 6 for a standard container) so that could explain how it's hit, it's possible a normal container would go under - just... Still no real excuse but could explain why it happened.
It's not far from it, if you look at the front and rear, right-hand side of the trailer it appears the container has been wrenched loose. It wouldn't have taken that much for the sole remaining restraint to fail and it to fall off - woe betide a car behind or heading the opposite direction.
richw
10 Jun 2010
Liskeard
The bridge is 13'9, I'm trying to work out what the height would be of the low loader bed, I can't picture but imagine somewhere between 5' and 6'. An 8'6" container would go under with the low loaded bed up to 5'3 (prob 5'6 in reality knowing signs state lower than will actually fit under). A 9'6 has no chance as no way is the bed less than 4'6 from ground level.
ComUtoR
13 Dec 2013
Worth taking the chance then :roll:
Jonny
10 Feb 2011
More precisely, it is restricted to vehicles under the the specified height, so even if they make it, it's still illegal.
10 out of 10 for sarcasm, but seriously though, some people think that anything is OK as long as they are "doing their jobs". That is no excuse for putting others at risk. If anything, it's worse when ^bystanders^ (including train passengers) are put at risk.
In fact, charges of railway endangerment should be considered for any bridge bash.
Chris M
4 Feb 2012
London E14
Surely with modern satnav technology, some kind of alert system could be fitted inside double decker buses that gives an audible warning if the driver is approaching a low bridge? Could be fitted to HGV's too, I'm sure the insurance companies would love it
Dragon's Den, here I come!
London's iBus system I believe does include this feature. It's not ideal though as it will sometimes generate alerts for bridges over side streets even if bus does not leave the main road. This is particularly the case when running off-route for any reason I suspect.
Crying wolf (or low bridge) too many times is not good psychology.
ian959
9 May 2009
Perth, Western Australia
Out of interest, does Network Rail send an invoice to the lorry owner/driver for the cost of repairs to the bridge after a bridge strike? Or does it all get left to the general inadequate non-deterrent fines issued by the courts, if the matter gets that far?
All the Tulse Hill bridge tells us that no matter how much signage you put up, in both imperial and metric measurements, so-called professional drivers continue to just ignore the warnings and use the shorter route rather than the trouble free bypass route.
As for the double decker being off route in Rotherham, that is all well and good but it does not excuse the driver for not immediately recognising that his vehicle isn't going to fit. Good old Mark 1 human eyeballs tell you that... makes me wonder what the driver was thinking/doing.
Haydn1971
11 Dec 2012
Sheffield
If there's a known debtor a local authority would do this for damage to their equipment - such as sign/streetlight knockdowns, more often than not the debtor is not know. I'd be very annoyed if Network Rail aren't issuing bills for damage to hauliers and bus operators for damages. Although it does open the question, would their insurance cover this third party liability of what is in effect an unlawful act in the case of passing a circular height sign.
Ash Bridge
17 Mar 2014
Stockport
How where do you find these professional drivers?
Perhaps the training process of LGV drivers needs to be looked at, e.g. potential train drivers (and probably airline pilots) undergo psychometric and other tests to determine suitability, there should be more emphasis on a candidates attitude and not just the ability to physically drive the vehicle.
Antman
3 May 2013
Hardly very practical, whilst there is no excuse for hitting a clearly signposted low bridge the bottom line is that we all make mistakes. Is there anybody on here who doesn't make mistakes? Only one so far it seems;)
richw
10 Jun 2010
Liskeard
Perhaps some enforcement is needed. Sit a police sting near a low bridge. Vehicles squeezing under but over height hit them with a fixed penalty.
21 May 2014
If it's practical for train drivers, why is it 'not very practical' for lorry drivers?
Just needs a change of attitude in the industry.
Sadly such changes only ever seem to be bought about in the wake of catastrophic accidents.
Ash Bridge
17 Mar 2014
Stockport
Oh, I certainly have made mistakes and never said I didn't, but in 35years never managed anything near as serious as a bridge strike.
Agreed, spot on!
Antman
3 May 2013
What change of attitude? How exactly is this going to work? The industry is more safety conscious than it's ever been. The question is, how do we stop human error?
al78
7 Jan 2013
If someone deliberately ignores warning signs can that really be classed as human error or are we now crossing the boundary into carelessness and recklessness?
The fact is, a motor vehicle is a potentially destructive machine when misused and the driver has to keep their concentration up at all times to avoid threat to life and property. I was almost killed earlier this year by a driver who had a momentary lapse of concentration and whilst I have sympathy for the driver I still think he needs to face the legal consequences of his actions.
Antman
3 May 2013
Obviously if somebody deliberately ignores a warning sign it's different although I can't imagine many drivers doing that in the case of a low bridge.
Sadly people are killed and injured every day in road accidents most of which are caused by human error on somebody's part.
richw
10 Jun 2010
Liskeard
Bridge strikes are:
Careless- Yes,
Deliberate - No way.
Although not the same thing, I have a roof box on my car at the moment. Last Friday I hit a height restriction barrier entering a car park at less than 5mph. I knew I was driving my car, but forgot I had the extra height on the roof.
With trucks the tractor unit will go under most bridges easily, its the height of the trailer and remembering if there is extra height on the trailer.
I'd say its easily done forgetting if something is higher than normal to forget the extra height.
