Well funnily enough, I am visiting there tomorrow.
Don't think it was a taxiway, more likely just an road access bridge to the factory on the east side of the line
Yes, it was.
Elmdon for those who aren't familiar with the area is where Birmingham airport technically is, the airport only used to play host to light aircraft due to it having a tiny runway.
However, they extended the runway (I know this because my aunt and uncle were onboard the first plane to land on it) so it could cater for airliners, next they built T1 which unless you are flying on a private jet is where you fly from now.
The plan was for the runway to face the opposite direction however this was not possible as the aircraft would plough straight through fort Dunlop.
So, with the runway facing the way it does today it makes the airport the 8th most dangerous in the world because even though its completely normal in good weather, when it gets windy, it is
very dangerous (if that has put you off your next holiday, just remember that you will have the best pilots there is!)
