Bridge Bash Lymington Branch
8 Sep 2008
Yet another bridge bash on the Lymington Branch this is roughly the tenth this year on the branch
Lrd
26 Jul 2010
According to Twitter it was all clear an hour ago.
Lrd
26 Jul 2010
I have noticed that there were quite a few this year, do you know if it is the same bridge every time?
33011
8 Sep 2008
No not the same bridge every time there are four low bridges I think. I heard it was Ampress bridge today and I think that one tends to get clobbered more than the others being on the main road. I wonder how many are due to sat navs? Do they make a HGV/PCV version? If not someone should invent one
142094
7 Nov 2009
Newcastle
Either that or start sending the bill for any delays and repairs to the bridge to the HGV company concerned.
Yes, but many of these mickey mouse firms won't pay for it. No-one is going to force them to act responsibly, and the costs of their blunders are not passed on to those responsible, so it will keep happening. :-x
GearJammer
12 Nov 2009
On the Southern
Was it an HGV that hit the bridge? Nice to see were getting the blame again, i seen a picture this week of a tractor and trailer that hit a rail bridge, ive also seen numerous pictures of buses hitting bridges.
Maybe the signage needs to be improved as most signs don't state the truth anyway, as proved by the fact that only yesterday i took my 14'6 truck under a 14'3 bridge, and earlier in the week i took it under a 14'0 bridge..... so whos at fault?
HowardGWR
30 Jan 2013
Gulp! :cry:
Lockwood
4 Apr 2013
Signs are meant to be at 0", 3", 6" or 9", so you will not get a precise height.
It is also a clearance, not the physical height.
They are also designed to under-read; a bridge with 14'5 gap will be signed as 14'3 at the most, so a 14'4 lorry will fit under.
Of course, you have the two sets of signs as well, the triangular warning: "Warning! This bridge has a 14'3 clearance! Taller vehicles may have a problem here!" and the circular mandatory sign: "This bridge has a clearance of 14'3. Taller vehicles MUST NOT pass this point."
Murph
16 Feb 2010
Other than the hopefully extremely rare case where a sign erroneously indicates a higher clearance than actually available or is missing, it is pretty much always 100% the driver's fault (there might be some other rare cases, but I can't think what they will be right now).
Some thoughts for you to ponder:
Will your 14'6" truck fit under that same 14'0" bridge when it's empty, as well as when it's loaded?
If you've got air suspension, what about if there's a fault in the system that causes it to ride a little higher than normal?
What about just after a service where the suspension was worked on?
What if you are driving a different vehicle which is also marked 14'6"?
What about a bridge where the road dips down as it goes under the bridge? On a longer wheelbase truck than the one you drove last time?
Are you prepared to bet your license, insurance, career, etc on it?
The one thing which seems guaranteed to happen if you routinely treat these signs with casual contempt, is that YOU WILL CAUSE AN INCIDENT, sooner or later!
33011
8 Sep 2008
Yes it was a HGV. Here is the same bridge in may
http://www.dailyecho.co.uk/video/128503/?page=3
BestWestern
6 Feb 2011
Got to wonder then how many 'bashess have been caused by truckers (or indeed drivers of other large vehicles) assuming that the plates were wrong and going tanking straight at the bridge?! Can't be a particularly good tactic.
richw
10 Jun 2010
Liskeard
My £100 TomTom has a HGV setting where you input dimensions of your HGV when you select HGV mode
Darren R
26 Jan 2013
Lancashire
Now there's a glimpse inside the mind of a trucker...now I understand why bridge strikes are so common. :roll: I always wonder what part of 'low bridge' it is that drivers don't understand - it turns out they think the signs are telling porkies! :lol:
PermitToTravel
21 Dec 2011
Groningen
This is precisely what causes bridge bashes.
richw
10 Jun 2010
Liskeard
No! A vehicle 14'6" will fit under a 14'0" Bridge.
See section 4 to the traffic signs manual, para 7.7.
According to that link a 14'6 will not fit,
should be at least 3 inches less than the measured height to allow a safety margin and should be expressed to the nearest multiple of 3 inches.
this suggests that a 14'5 is the tallest that should fit under a 14'0. This article implies take the height knock off 3 inches and round down to the nearest 3inches. 14'6 knock off 3' will be 14'3 rounded to the nearest 3' will leave 14'3.
There was an incident about 12 months ago where a truck driver had been driving his truck under a bridge every day for several years so knew it fitted. One day he hit the bridge and couldn't understand why. Investigation found that the road was resurfaced and the surface was several inches higher leaving less clearance and the council were deemed responsible for the incident for not updating the signs.
BestWestern
6 Feb 2011
But crucially, was the bridge plated to allow the lorry through or not? I can't imagine a council being blamed for somebody driving a lorry straight into a bridge which carried a sign stating that it was too low for the vehicle - regardless of how many times they had done it in the past!
Even as a PCV licence holder I had genuinely never even considered that a bridge bash could occur for any reason other than catastrophic inattention at the crucial moment. However, I'm honestly wondering how many of them have been down to a driver totally ignoring the warning signs because they thought they knew better!?
I know people laugh at me when I suggest things like this.....
But if I ever did see an argument for a rollout of a new railway network based around high speed trains..... this is a good one.
I doubt HS1 has any low bridges....
Lockwood
4 Apr 2013
Some of them have been the driver being caught out, as they only ever drive under a certain bridge on passenger service in a double decker.
They do a special service (school bus, for example) and terminate happily.
Running ECS back to the depot (with no defined route for the move), they know the shortest route is to go that way, so off they go.
*splat*
OuterDistant
25 Oct 2010
TOPS Area 43
How about this: in the event of a bridge bash, the lorry's owner is fined £10,000 for every inch the lorry's height is over the height on the sign.
Gwenllian2001
15 Jan 2012
Maesteg
Most, if not all, bridge bashes could be prevented by a bar spanning the road a few yards in advance of the bridge itself.
High Dyke
1 Jan 2013
Yellabelly Country
Living in a location with two of the most bashed bridges in the country i agree it would be a good suggestion. It was suggested where i live only for the local council / civic society to disagree - citing they would look unsightly, amongst the reasons for not wanting them.
An incident on one of the out-of-town bridges was avoided recently. The German lorry driver feigning to have poor English language skills when stopped, before he attempted to drive his overheight vehicle under a bridge; he soon changed his attitude when he was addressed in his native tongue.
I too hold a PSV licence (yes i know it's now a PCV licence). One of my former employers always complained at me because i refused to take a double-deck bus under the railwy bridge adjacent to their depot. The bridge has the circular signs stating the height - all of their buses were taller than the height shown on the bridge - even though two of the vehicles would actually go under the bridge. The company found out the hard way one day...
34D
9 Feb 2011
How's about the railway authority be instructed to increase all bridges to the national height of 16'6" to prevent them all?
jopsuk
13 May 2008
The bridge that took the Newquay Branch over the A30 (before the road was massively rebuilt to a new alignment) use to have everything short of a steel bar over the road- it had over height detection some way up the road that triggered multiple flashing signs and sirens.
Which were routinely ignored.
GearJammer
12 Nov 2009
On the Southern
Thats a brilliant idea! :grin:
And how do you suggest they do that?
Dig the road out and improve the foundations to the bridge! Or increase the height of the railway..... or both!
Buttsy
20 May 2011
Hanborough
I would suggest the opposite in that the Highways Agency are required to pay for all the bridges to be raised to 16' 6", as the railway bridge was there before the tall lorry was built. Putting the onus on councils/highways agency would no doubt improve signage etc and all the 'delay minutes' caused by the bridge strike, recoverable from those parties, rather than Network Rail.
I personally cannot see why road bridges over/under railways are not the responsibility of the Highways Agency, all other bridges appear to the their responsibility (or the local council's).
It appears to be, as in most level crossing incidents, it is the railway's responsibility to deal with the mess ignorant/inattentive drivers cause by striking bridges.
