Bredbury: curious piece of infrastructure
7 Nov 2009
Newcastle
Judging by the colours on the cement mixers, it is Tarmac Bredbury readymix concrete. From the looks of it there is a gravity discharge shed on the line which feeds into the main plant.
Signal Head
26 May 2013
Was looking at my 1:25,000 map of Salford/Manchester and spotted this curious piece of retained infrastructure.
From Google, looks like it services some kind of mill.
Does anybody know its use or even if is still in use?
https://maps.google.com/?ll=53.42446,-2.11379&spn=0.007966,0.020857&t=h&z=16
Assuming you mean the short curved branch line in the cente of the map, it was newly built sometime in the 1980s to serve a containerised waste plant.
Similar facilities exist at Northenden Junction, Agecroft, and Dean Lane.
It branches off the former CLC Glazebrook - Godley line, which closed as a through route in 1980 following damage to Tiviot Dale Tunnel in Stockport during motorway construction work.
The same truncated route also serves a stone terminal situated between the Romiley line viaduct and the supermarket which now blocks the CLC route.
As far as I know the waste sidings are still in use, not sure about the stone terminal though, it's had a rather chequered life.
John Webb
5 Jun 2010
St Albans
Picture of the divergence to the waste plant (click on picture to get the larger original):
Lines to Bredbury Waste
© Copyright Gerald England and licensed for reuse under this Creative Commons Licence.
Unfortunately no one seems to have photographed the Tarmac or Tilcon plant further west - although the shine on the rails implies that the stone terminal was in use still in 2011 when the above picture was taken.
Sox
22 Oct 2010
Funny, in my original question, I must confess to not spotting the spur line going to the waste recycling plant and was only focused on the remains of the old Glazebrook line. Somewhat surprisingly, during my drive into Manchester this morning, the plant fire was wall-to-wall on the news.
Some interesting responses to my original query. In particular, how some motorway num-nuts managed to damage the tunnel and close the through route forever.
Signal Head
26 May 2013
I think an item of plant working above the tunnel discovered a hitherto unknown shaft, by falling down it. This damaged the lining, and the line was closed 'temporarily'. This line used to carry all the Yorkshire coal traffic (which had come via Woodhead) to Fidlers Ferry power station. That traffic had to be diverted via Guide Bridge and Stockport, then via the LNW Cheadle branch to regain the original route at Northenden Junction.
The closure became permanent sometime in 1981, when of course Woodhead had closed anyway.
I heard at the time that the damage wasn't necessarily terminal, but the tunnel was propped as a precaution and that effectively meant the end of the route.
The line stayed open from Woodley to serve the 'drops' at Portwood, but was later cut back further to serve a new facility replacing Portwood, to avoid the expense of a bridge over the new motorway.
There are some photo's of the tunnel as is it today on 28 Days Later, showing the propping, and more on flickr, including a few of the route when it was open, such as this one:
http://www.flickr.com/photos/deadmans_handle/6284057175/
Recycling plants seem to be catching fire with depressing regularity at the moment.
Probably helps the incinerator-boosters.
Mugby
25 Nov 2012
Derby
If you were a conspiracy theorist (which I sometimes am!) you could really make plenty out of that!
Incidentally, I believe all Manchester - Sheffield services are diverted via Bredbury and Romiley this weekend.
Ships
25 Apr 2013
When I was seconded as a maintenance tech this was my patch. I'm sure the Tilcon plant was still in use in 2012, least the rails where still shiney.
Bevan Price
22 Apr 2010
According to RTT, Bredbury Tilcon had a train to Tunstead on 20 August 2013
http://www.realtimetrains.co.uk/train/H02895/2013/08/20/advanced
RichmondCommu
23 Feb 2010
Richmond, London
Signal Head
26 May 2013
Indeed the current Bakers Rail Atlas suggests that both facilities are still open. In terms of the Tunstead train where and when does the loco run round it's train to face the right direction to enter the facility at Bredbury?
When the terminal was built it had a run-round inside the facility. This was lost when the supermarket was built across it (the terminal may have been closed at the time). At this time both branches operated as independent single lines, worked under OTW without Staff regs (track circuits detect a train going in, then lock the signalling to prevent another movement inwards until one has been proved outwards).
Around 1996 the terminal was needed back in use, so the layout was altered to combine the two sections and provide a run-round outside the Tilcon ternimal, using the track of the formerly independent Waste branch. You can see part of the layout in the picture John Webb posted further up the thread. Following this change, it is only possible to send a train into one of the terminals at a time, since they both share a single line connection at Woodley.
