D365
- Joined
- 29 Jun 2012
- Messages
- 13,195
"Electronically controlled pneumatic" braking, a system with a power and data base running the length of the train that allows independent electronic control of all brakes in the formation, and data passage between vehicles and the locomotives. The air brake pipe is retained solely as a method of continuously refilling the reservoirs in the vehicles. It's been deployed on some heavy haul railways in Australia, South Africa and North America but the up front cost of mass retrofit has held it back elswhere.
With such a system you can provide continuous train completeness checks, transmit multiple working data and any number of other things.
For older freight locos that do not have any form of electric brake control, the ETCS service brake command will interface with the air brakes by means of an electropneumatic system.Interesting, thanks.
This does sound like a solution if not a simple one. But likely still cheaper and easier than equipping all freight wagons with transponders or using a dedicated trailer.
The problem AFAICS will be getting the whole fleet equipped, with the fragmented ownership and maintenance of wagons. Think NR/GBR will need to take a lead here.
For locos with electric brake control, Freight ETCS will replicate a driver's full service brake application.
Freight ETCS does not include any provision for electronic control of wagon brakes, but in any case, ETCS intervention is (certainly at Level 2) only a last resort in response to driver inaction.
