Eric
Why is this coming in at £26.50 when I can get to Blackpool and Preston cheaper which are further afield?
Because the £26.50 Bradford to Colne Off-Peak Return (SVR) is route "Any Permitted" and is valid via Manchester.Why is this coming in at £26.50 when I can get to Blackpool and Preston cheaper which are further afield?
Are you sure you are comparing the same type of tickets? A Bradford FSQ to Colne SVR (off peak return) is £26.50 (I assume this is the ticket you are referring to). Whilst a Bradford FSQ to Blackpool N SVR is £33.70 and a Bradford FSQ to Preston SVR is also £26.50.
Bradford - Preston is coming in at £15.70 and Bradford - Blackpool is coming in at £20 mate.
The £17.50 Bradford - Preston Anytime Return (SOR) and the £21.80 Bradford - Blackpool SOR are route "Burnley". Unfortunately there is no Bradford - Colne route "Halifax" or route "Burnley" fare.
The £17.20 Leeds - Colne route "Halifax" SOR can be used instead as a Bradford to Colne return ticket. There may (or may not) be cheaper options involving splitting.
As I said you're not comparing like for like. Those fares are off-peak day return and an anytime day return whilst the £26.50 is an off-peak return (return portion valid for a month). As John @ Home said those fare are also routed via Burnley rather than any permitted route.
It does seem strange to not offer a off-peak day return from Bradford to Colne, but offer one from Leeds.
Yes it is rather, they offer an Anytime day single, Off-peak return and an Anytime return and that's it for BDI - Colne! If you wanted to query this further you would have to talk to TPE as they price this flow.
It's my elderly mothers birthday next Thursday and she fancies a trip to the new Boundary Mills complex as part of her celebrations.
£26.50 x2 = £53 is too expensive IMO for this journey.
I've tried splitting with a Bradford - Burnley Stations ticket but that would mean either a taxi or bus from Manchester Road station to either of the other two on the Blackpool South-Colne line.
Will I be ok starting and stopping short on a Leeds-Colne day return ticket?
Most (if not all) trains stop at Hebden Bridge.
Peter
Have you tried travelling via Skipton and then getting a bus over to Colne from Skipton (every 30 minutes). The bus should call via the train station and roll over to Colne and beyond. Get off at Colne Bus Station and I think there is a bus that rolls round visiting Boundary Mills.
You are looking at a fairly long trip by train with a nearly one hour wait at Accrington on the way there
http://www.lancashirebus.co.uk/explore.jsp?exploreAttractionID=241
http://www.boundarymill.co.uk/colne_mappdf.pdf?qs=NG32+2AB&countryCode=GB
I am unable to tell you the cost of travel for yourself on the bus but there is a rail bus ranger for yourself http://www.lancashirebus.co.uk/cmsUploads/fareType/files/East_Lancashire_Day_Ranger2011.pdf
The Pendle Green Bus is operated by Tyrer who do not appear to have a website. The bus runs hourly calling at the bus station and at the door of Boundary Mill.
Does she have an ENTCS and a senior railcard?
Split at Hebden Bridge
Bradford Stations - Hebden Bridge CDR £3-90
Hebden Bridge - Colne CDR £8-60
Total £12-50. Most (if not all) trains stop at Hebden Bridge.
Peter
Total £12-50.
In addition, if your mum holds a West Yorkshire Concessionary Travel Pass, she can use this to travel by train Bradford Interchange - Hebden Bridge for £0.50 single or £1.00 day return (after 0930 Monday to Friday, and all day at weekends and bank holidays).it's going to be the train over the bus for the fact that they have toilets if mum needs to go.
She doesn't possess a senior railcard although for her annual trip to Cleethorpes over the festive period I should consider purchasing one for her.
