Bradford Interchange Signal Box
Eric
21 Oct 2010
West Yorkshire
I was at the Interchange earlier today when a class 150 bound for Manchester Victoria slammed and screeched the brakes on, right at the end of Platform three because the route indicator had been set to B and the Branch line to Leeds.
Who would have been at fault if the driver had continued to Leeds on the branch?
Is the Interchange signal box under York control or is it still operated manually?
louis97
14 May 2008
Derby
Currently controlled by Mill Lane Junction Signal Box, the junction where the line diverges towards Leeds and Halifax. In October this will close and control transferred to a workstation in the York ROC.
Eric
21 Oct 2010
West Yorkshire
So human error then?
superkev
1 Mar 2015
west yorkshire
I understand that, perhaps unfairly, any incorrect routing is the responsibly of the driver.
K
Stampy
21 Sep 2014
Peterborough
I would have thought the driver would have REFUSED to move his train until he'd received the CORRECT path....
Eric
21 Oct 2010
West Yorkshire
My interpretation is the guard gave the buzzer and off it went for about five seconds up the hill before a loud screech brought it to a halt.
jdxn
2 Nov 2017
If the signaller sets the route incorrectly and the driver doesn't take it it's the signallers fault. The the driver takes the route the blame is 50/50. That is unless by the time the driver knows its the wrong route too late to stop (certain high speed junctions) in which case its the signaller's fault.
Tomnick
10 Jun 2005
Not if the route indication wasn't visible from the position from which the train started.
Ianno87
3 May 2015
The route indicators are sometimes not possible read until the train moves towards the signal at Bradford Interchange.
I would presume modern LED theatre indicators are easier to read from a distance then older lamp indicators (doew Bradford Interchange have the latter?)?
16 Sep 2013
Somewhat easier. At Bradford Interchange some of the signals are poorly aligned, and are barely visible from where the train is stood at the platform, being located someway up the hill towards the signal box and sometimes round a l/h curve. Of course this is not helped by the use of 30 meter trains; the signals are positioned for longer trains of yesteryear. As part of the Calder Valley resignalling works all signals controlled by Mill Lane (and Halifax, Milner Royd and Hebden Bridge) will be replaced, hopefully on a better alignment.
Tractor37
23 May 2017
As a driver for the same company, there is no issue viewing the signal and route indication from where trains start on platform 3. If the driver had not stopped, which isn't difficult at 15mph, it would be deemed as driver taking the wrong route on his record.
