BR Standard Water Cranes
13 Nov 2025
Ashford, Kent
Hi, could somebody explain this device on top of what is described in these 1955 photographs as Standard Water Crane
Is it a wheel, does it rise & fall on the eccentric block beneath it, is it an on/off valve..? WCRN-16-D1.jpgWCRN-13-D1.jpg
John Webb
5 Jun 2010
St Albans
It's a wheel. It and the 'eccentric block' beneath it are designed to help make the arm return to a position parallel to the track(s) rather than overhanging a track where it might be struck by a moving locomotive or train.
13 Nov 2025
Ashford, Kent
Thankyou John, as a Plumber that wasn't the first thing I would have thought of but it makes a lot of sense. There must have been a rising & falling slip-joint to allow this to work, I wonder what sort of maintenance liability that was for the Gas & Water/ODM boys..?
John Webb
5 Jun 2010
St Albans
I think water cranes were the responsibility of the civil engineers. Most water cranes had such rotating joints; one problem was that, even with minor leaks at the joint, the arm could freeze in cold weather in either the normal position, or worse still freeze in a position where it trapped the loco whose tanks or tender were being refilled and prevent it being used! Coal-fired braziers (often called 'fire devils') were placed next to such columns in cold weather in attempts to prevent such freezing.
