Bought ticket on forum not given ticket for full journey
joebassman
5 Mar 2020
Stowupland
I bought a return ticket from Stowmarket to London Liverpool Street. However, even though on the email it says from Liverpool Street to Stowmarket changing at Stratford for the return, on the eticket it only says from Stratford to Stowmarket. When I asked at the ticket office they said I had to buy a ticket from London Liverpool street to Stratford as the one I purchased on the forum is not for the full journey.
I selected Stowmarket to Liverpool street return when purchasing on the forum, so why I have I only been given a ticket for part of the journey for the return?
The booking ref is:
Hadders
27 Apr 2011
The booking ref is:
I've removed the ticket collection code from your post as anyone could go and collect the ticket with it.
I suggest contacting Trainsplit directly about this, the staff are very helpful.
OscarH
15 Sep 2020
Crawley
I agree with the advice to contact support. I know why this has happened, and I believe it should now no longer happen for new bookings. It relates to a link in the industry data between Liverpool Street and Stratford of a mode which usually should not be ticketed, but in this case should be as it's there for when engineering work closes the NR line, and tickets not usually valid on the tube are accepted there.
The data is a bit of a bodge - ideally it wouldn't be permanent, and would instead be added as a dated link just for engineering days (I believe it's cited the engineering work is too often, it makes this too much work), and having a mode which is sometimes ticketed and sometimes not is clearly completely unusable (adding a new mode would unfortunately take a very long time, the industry is not quick with this type of change).
It has been discussed that a "tube" link would work better here in theory because of interavailability rules, but there are some retail systems that don't support interavailability properly, so they don't want to do that, and keep the ambiguous state instead.
infobleep
27 Feb 2011
Haywain
3 Feb 2013
Well there was an 8 digit alphanumeric code that to my untrained eye looked like a ToD code, so I wasn’t taking any chances!
Some retailers give such reference numbers for all bookings, while other only give them for ToD.
The reference the OP gave was an 8 digit ToD-style alphanumeric code, which I believe the forum's ticketing site (as a TrainSplit derivative) uses as the booking reference - even for transactions fulfilled by e-ticket.
Spot on.
Adam Williams
2 Jan 2018
Warks
This is correct.
I don't particularly like it, and it may well end up changing.
joebassman
5 Mar 2020
Stowupland
Trainsplit have agreed to refund the cost of the ticket I had to purchase from Liverpool Street to Stratford as a goodwill gesture.
Thanks for the suggestion.
30907
Thanks for letting us know. Not that I am surprised :)
