Bootle docks to Drax biofuel
stephen rp
25 Jun 2016
To avoid the 1 in 45 bank out of Manchester Victoria, the loaded trains take a circuitous route from the Bootle Branch via Warrington Bank Quay, Hartford, Altrincham, Stockport, Ashton Moss (then turning west!), Miles Platting, Calder Valley....
Would it not be simpler to go Chat Moss to Parkside, onto the WCML to Farrington Junction, then via Blackburn to the Calder Valley?
The route over Copy Pit (East of Burnley) is equally steep.
Adrian Barr
2 Jul 2020
Doncaster
Max weight over Copy Pit Summit for a 66 is 1725 tons (trailing) in the loads book; the biomass trains to Drax weigh closer to 2200 tons
Rail Quest
8 Apr 2023
Warrington
I'm assuming there could be pathing issues on parts of this route? Specifically Wigan to Farrington, it might be a challenging squeezing in a diesel-hauled 2000+ ton train into the timetable. Yeah, you could probably argue the same applies on their current route, but the only problem there is presumably Weaver Jnc to Acton Bridge which is only a handful of signal blocks.
Ash Bridge
17 Mar 2014
Stockport
I'm sure they tested with a 60 at one point but they carried on with the regular route round the houses!
I wonder if it was due to the possiblity that a 60 would likely not have 100% availability hence the only substitute being a 66?
Oxfordblues
22 Dec 2013
If I were on the Class 99 project I'd do trial run Liverpool-Drax via Miles Platting bank with electric haulage from Olive Mount.
I'm not sure the wires reach the top of Miles Platting bank if you are heading to the Calder Valley.
Perhaps it could go via Stalybridge when TRU wiring is finished (if Drax is still taking biomass by then).
Rail Ranger
20 Feb 2014
Drax Power Station is moving to standby status from 2027. Will biomass even be imported through Liverpool from then?
Northampton
Then double head or bank.....
Double-heading requires a 2nd loco, and banking requires extra paths, crew, infrastructure and so on on top.
They do not, limit of electrification on the Rochdale Fasts is 50 chains from Manchester Victoria (0 milepost).
xotGD
4 Feb 2017
The long term future of Drax depends on whether they go ahead with retrofitting CO2 capture.
If that happens, there'll be biomass trains for many years to come.
