Body side / Hazard lights
pompeyfan
24 Jan 2012
Saw earlier on social media the issues that traincrew have with the body side lights against low sunlight or at night against LED signals showing a restrictive aspect. A commentator suggested the possibility of changing all body side lights to something like blue.
is this a solution looking for a problem, or does the idea actually have some merit?
HamworthyGoods
15 Jan 2019
Blue lights are already used on the body side but they have a different meaning to orange ones and don’t require the train to be stopped.
Rule book extract
RGS Rulebook TW1, 10.6
"If you see a class 325 electric multiple-unit train pass with a blue cant-rail light illuminated near the roof, you do not need to take any action."
Llama
29 Apr 2014
Didn't that instruction/info get removed from the rule book itself a good few years ago 'as a matter for competence management and training'?
hwl
5 Feb 2012
The current ORR/RAIB position on BILs (and interlock) is useful as guide but not definitive or failsafe, hence a solution in serach of a problem. I can't see colour making much difference.
bunnahabhain
8 Jun 2005
If you can see them there are other ways you can check interlock is made. Bearing in mind the light on the coach you are working from doesn't extinguish until you close your door, and on CDL fitted stock it is nothing but an indication that bolts are retracted, it gives no confirmation that doors are locked.
Monkeyfuzz
22 Apr 2019
As a conductor, it’s a good indication that the doors are correctly closed but I’d never not look at the doors before closing my local.
When it’s an issue (glare) is when the train stops out of course as we will always stick head our cess side to check if a hazard is lit before further investigation. Because of glare, it’s not always clear if it’s lit.
43066
24 Nov 2019
Yes indeed.
On modern units/coaching stock with BILs you wont get interlock unless the interlock circuit has been completed and then, absent a passcom/egress activation, the BILs will have extinguished (they’re linked to the interlock circuit, IIRC).
In relation to HSTs and mk3s (any other types still remaining with hazard lights?) there’s no such thing as interlock, and the absence of hazard lights doesn’t mean the doors are closed, in any case.
A solution looking for a problem, in my view.
whoosh
3 Sep 2008
The problem with changing them to blue would be that extinguished blue lights on the exterior would mean the doors were shut, but illuminated interlock light in the cab (also blue) would mean the same thing.
If all the lights are blue, but one lit up means the opposite of another one lit up, there's possibility for confusion or error if they are the same colour.
43096
23 Nov 2015
For slam door Mark 3s, yes, but the HSTs modified with sliding doors do have interlock.
jopsuk
13 May 2008
That would be far from ideal- I realise this is upping the stakes somewhat, but an issue identified in the aftermath of the Three Mile Island disaster was that in the control room some systems indicated red (not running) in the normal state, some indicated green (running) when normal- so when things started to go wrong there was a wall of red and green lights but it was hard to tell at a glance what was safe and what wasn't.
