Blood pressure
Webby
6 Sep 2016
Can anyone tell me the blood pressure limits for tube operator medical, i dont suffer from high bp bu get a bit of white coat syndrome .also if u fail is that it?
godfreycomplex
23 Jun 2016
I had exactly the same problem - my BP was high on the test and they sent a letter to my GP to request 24 hour monitoring. Once that came back clear; I passed. That wasn't with TfL but I wouldn't imagine the procedure is too different. Also might be worth mentioning to the doctor/nurse in charge; from what I've heard it's quite common for those with no history of "white coat syndrome" to have elevated blood pressure on the medical as there's a lot riding on it.
Aivilo
15 Jan 2014
Anything that's high they will request a 24 hour monitor.
I wouldn't worry about it to much I'm the same in a medical environment and it's never gone against me
Lasbrisas
13 Dec 2016
Mine was quite high until I went to the doctors to do something about it. I suffer from White Coat Syndrome and mentioned to my GP about going for medicals. He told me to tell the examiners to contact him as my BP is now normal under normal conditions and he would verify that my BP is normal.
Webby
6 Sep 2016
Do you rememner how high?
Webby
6 Sep 2016
Can't remember exactly I'm afraid but it was somewhere around the 150/110mark. Bear in mind that I was only 20 when I did it; so the limits could have been a bit lower.
That is really high. So i think i should be ok thanks
me123
9 Jul 2007
Really try not to worry about it - worrying will only increase your blood pressure! There will be separate limits for the systolic and diastolic numbers - I'm not sure what they are exactly. Since it's now well established that hypertension cannot be diagnosed on the basis of one clinic visit alone, if it's high on the day they'll give you a 24 hour monitor - and if your BP is normal that will clear you. Relax - you'll be fine.
Besides, even if it is high, I understand that you can be on antihypertensives as a driver so presumably treating it is an option as well.
Webby
6 Sep 2016
Thanks
