From https://www.railforums.co.uk/threads/bletchley-eastern-entrance-updates.295181/#post-7700446:
Based on my experience of Bletchley e.g. the old leisure centre and the present leisure centre car park, unless that was wholly inside the gateline it would soon be a hive of antisocial behaviour and would strongly smell of urine and illegal smoking products.
I see no issue with "downgrading" Saxon St, it's not a major thoroughfare (e.g. it's not a proper grid road and never really was - primary access from the rest of MK to Far Bletchley is via Standing Way/Buckingham Road) and already has a 30mph limit and nowhere near enough traffic to justify being dualled. Indeed, it being dualled probably causes accidents because the lane layouts of some of the junctions are slightly confusing. I would even consider dropping that section to 20mph (not enforced) with a zebra crossing rather than Pelican across to the new entrance, it'd cost people seconds on their journeys and make it a much nicer environment. And I find the National Speed Limit "racetrack" section under the Marston Vale Line bridge a bit silly too, that needs a 40 on it, it's hard to drive it above 45-50 without being reckless due to the blind curves.
I do agree with you on the progressive downgrading of the grid itself, but this isn't really the grid even if it technically has a V number on the signs. The grid really ends at the Tesco double roundabout.
(Curiously it's only that side of Bletchley - you rarely if ever see ASB in the station building itself, and that's open 24/7/363 sometimes without any staff there as there's no other way to the platforms!)
I'd really love to see a footbridge run from the EWR platforms right over Saxon Street to the bus station, but sadly the current MK Council administration is hell-bent on downgrading roads and forcing pedestrians onto them.
