Blackpool Trams News
markymark2000
11 May 2015
Great Britain
Yeah, that's been the case for most of the year I think - the later services (particularly those heading south) will carry very few passengers, so they cam effectively be sped up and work within the crew duties
No need for them to be listed separately though. Just tighten up the times shown so they are bare minimum. Then if the tram has more stops than normal, it's late. If no one gets on, the times are already tight enough that no one needs to wait. You can't just not advertise trips properly in the timetable because they can't be bothered to add times to the trips.
davehsug
8 Jul 2014
Trams going on to a reduced service for a few days, to allow for essential maintenance. Apparently it's a 15 minute Starr Gate to Fleetwood, with a shuttle bus from North Pier to North Station.
stadler
5 Jun 2023
Horsley
Just curious why did Blackpool Trans get rid of the route numbering so quickly. They introduced the T1/T2/T3 numbering at the same time that the Blackpool North extension opened. It was useful for identifying routes. But then only about a year later they have scrapped the route numbering. Does anyone know why they decided to get rid of this?
davehsug
8 Jul 2014
Was it ever needed? T2 and T3 never met apart from on Talbot road, so there was no need to distinguish them for passengers. Anything else was shown by the destination indicator.
barbette165
15 Nov 2010
Surely there was a need to differentiate when they were departing from North station.
JModulo
17 Nov 2013
67A
Standard has 143 left Rigby Road on a low loader, headed for the East Anglia Transport Museum.
davehsug
8 Jul 2014
Shockingly bad. I do fear that we really have seen the last of the heritage trams. They should be a regular & permanent feature of the system. Operators all over the world make it work, Blackpool can't seem to, probably because they don't want to.
Xenophon PCDGS
17 Apr 2011
One wonders if in 2026, passengers who use the tram service as purely a mode of commuting/traveling (which is what it is there to do) care one jot about this and are pleased to have modern trams to use.
davehsug
8 Jul 2014
Of course they are, but Blackpool is a holiday resort, and the tramway couldn't survive at it's current level without visitors. The heritage trams should be a great source of revenue, and attract more visitors, instead of the burden that BT seems to regard them as.
Xenophon PCDGS
17 Apr 2011
How do the tram fares compare to the bus fares (with the said visitors in mind) anf do visiting holders of ENCTS passes who have free bus travel in the Fylde area also have free tram fares
Lemmy282
8 Apr 2021
Sheffield
Only ENCTS passes issued in the area are valid on the trams, visitors have free travel on the buses but not on trams. This is the same for all tram systems as far as I am aware, although when Stsgecoach operated Supertram in Sheffield free travel applied to all ENCTS passes regardless of where they were issued.
Haywain
3 Feb 2013
Sheffield trams still accept all ENCTS passes.
Acathater
11 Dec 2025
NorthWest
To use the Blackpool trams an ENCTS pass has to be issued within the Blackpool or Wyre council areas. Not Fylde
However given the impending reorganisation of local government in Lancashire it's quite possible this will change in the next few years: one of the likeliest change seems to be to link Blackpool, Wyre and Lancaster and if that happens I can see the free trams getting cut.
davehsug
8 Jul 2014
Apparently 143 has only gone to EATM for completion of restoration. It will return to Blackpool in service condition. So hopefully, a glimmer of hope.
davehsug
8 Jul 2014
What was the source that you referred to that confirmed that 143 would be returning to Blackpool after the completion of the restoration?
It's on the Gazette website.
I would post a link but I don't believe it's allowed. but it's still on there today.
JModulo
17 Nov 2013
67A
As above, the owners of the tram have said its a one way move and there is no plans for it to return.
Towers
30 Aug 2021
When was 143 last out & about in use, I assume quite some time ago? Very sad to see Rigby Rd unable to complete work on heritage cars after so many generations of skilled expertise, but I guess if the skills are no longer employed there it is what it is…
Skymonster
7 Feb 2012
I appreciate that there are some [hopefully short term] problems with access to any of the tram facilities at Rigby Road… But its a sad inditement on the capabilities of the “Tramtown” Fitting Shop and the low likelihood of being able to run it on the Blackpool network once it is sorted (where would it be stabled if it was operational - no room at Starr Gate?), that the owners of 143 have felt it necessary to move it to East Anglia.
johntea
29 Dec 2010
In Blackpool the next few days so bought a 3 day travel ticket today, quite impressed so far…services pretty much bang on time and friendly on board staff…can’t ask for much more than that!
‘Press the stop button when you wish to exit the tram’ doesn’t sound quite right in my head for some reason though!
pr1
6 Feb 2026
Preston, Lancashire
The pressing a button to stop the tram issue is a bit quaint, I think, part of the charm!
davehsug
8 Jul 2014
I suppose it's because of the season loading. There are plenty of times when you're like sardines, and it's difficult enough to reach a bell, let alone an exit door!
philthetube
5 Jan 2016
There are quite a lot of stops beyond clevelys which ae not that well used, so no point in stopping at them all if not needed, also when busy they will non stop platforms if fully loaded and no one leaving.
py_megapixel
5 Nov 2018
Northern England
Sheffield trams also stop only on request, although most journeys do end up stopping at most points (contrary to popular portrayal on here, it is not in fact a ghost network devoid of any passengers)
West Midlands trams are fitted with stop buttons but I have no idea if they're used as I've only travelled at a time busy enough that the trams would have to stopped everywhere anyway.
tram21
29 Dec 2022
And Nottingham trams have stop buttons which are used, obviously its normally pretty busy but for example on a Sunday morning you can have an almost non stop journey if a tram was running late.
duffield
31 Jul 2013
East Midlands
I've got so used to the Nottingham trams always stopping at every stop at the times and places that I use them, I'm sure I'd forget to ring the bell if it was needed (in fact I have done this, just once, a long time ago).
