GRALISTAIR
I sent a load of photos to Dave. Loads of orangemen at hole in the wall, engineeers train near Sidgreaves-Darkinson and orangemen at Salwick. Further progress without doubt
Photo 6884m - the caption should read early 1970s electrification - this was, of course, a different phase from the 1960's, shown by the Mk3 catenary.
Lots of track work at Poulton
Does that mean the Fleetwood line points have been removed?
I believe the Fleetwood points have been severed, maybe a while back, forever cutting Fleetwood off from the network.
The abandoned wagons outside Bolton at Burnden have been removed.
Thank you Graham, hope you have a good flight.
Thanks, so points still in place for now. Also interesting to see progress being made on the restoration of the Fleetwood branch. Perhaps in a couple of years Poulton will be a little like Keighley, providing an interchange between a modern electrified service and a popular heritage line.
Fleetwood branch switch and crossing units all still in place as of today
More likely till the station gets remodelled during the blockade starting in November
That would make sense
That is sure some heavy engineering resources.
Remodel Kirkham - big job
Remodel Poulton-L-F
Remodel Blackpool North - big job
Resignal the lot - including Blackpool South
Finish off the wires
wowsers
I believe you are misunderstanding the work going on here at the Blackpool end of Poulton. As I understand it, once complete, the Fleetwood branch will be disconnected, the signal box demolished and the track slewed slightly to allow for an increased speed limits. I assume the vegetation clearance work is just getting "rubbish" out the way.
Sorry if this was unclear, by interchange I meant the proposed pedestrian link between heritage and network rail platforms. My understanding, however, is that the new track layout will allow a rail link to be re-instated if required in the future.
