Bizarre GWR map
williamn
22 May 2008
I hesitate to post such a trivial topic but I found this map truly bizarre. Why would anyone need a map of routes served by Turbo trains? I doubt many passengers would recognise them and it’s not like you’d plan your route to enable you to take what is a pretty hum drum train. To the average passenger the map is pretty misleading and could be taken to imply there’s a limited service between, say, Exeter and Plymouth.
DelW
15 Jan 2015
Possibly it's a map that is only displayed on board the Turbo fleet, so the service that the train is operating will always be on a section highlighted on the map. It would also emphasise that a passenger would need to change if heading beyond the thick line section. I agree that it's a fairly unusual presentation though.
The exile
31 Mar 2010
Somerset
There is a comparable IET one - I see the logic of what they’ve done, but it all too easily conveys the wrong impression to someone less than familiar with the railways out west.
Dr Hoo
10 Nov 2015
Hope Valley
Surely this is just like the Victoria Line trains, showing a line diagram of just the line?
Similarly Elizabeth Line trains not showing the entire ‘TfL’ system.
It’s being described in terms a bit like Christopher Columbus being told he’d fall off the edge of the world, whereas in fact other GWR routes are indicated, albeit ‘not all stations shown’.
What sort of ‘wrong impression’ is that? Should Merseyrail EMUs have maps showing everything including ScotRail?
The exile
31 Mar 2010
Somerset
Surely this is just like the Victoria Line trains showing a line diagram of just the line. Similarly Elizabeth Line trains not showing the entire ‘TfL’ system.
It’s being described in terms a bit like Christopher Columbus being told he’d fall off the edge of the world. Whereas in fact other GWR routes are indicated, albeit ‘not all stations shown’.
Yes and no. Those are clearly route diagrams. The GW ones look at a quick glance like a network map. What’s odd is that it’s by “type of train” not “type of service”. What does it matter to the general public whether 6 of the days 20 services are a 165 or 166 or whether it’s 7?
GoneSouth
17 Dec 2018
It also implies a direct service not calling at Bristol between Lawrence Hill/Stapleton Road and Keynsham/ Bath, does such a thing exist?
JamesT
25 Feb 2015
People might care about the different level of service offered on different rolling stock? Cycling provision comes to mind, where IETs have limited spaces that need reservations, whereas Turbos if you can get on with your bike in the doorway you’re fine?
AndrewE
9 Nov 2015
I like the way the buses are shown in Devon and Somerset though, reminds me of the Swiss National timetable of 30 years ago...
The exile
31 Mar 2010
Somerset
That would be fine if there was any degree of consistency or predictability. GWR don’t quite operate the “random unit generator” that Northern used to love but on various routes there are at least 3 very different kind of train that could turn up (that’s assuming that you consider all turbos to be equal, which for this purpose they probably are.)
tram21
29 Dec 2022
Yeah to be fair unlike other operators, your train type does actually matter more on GWR.
It's a slightly odd map, but I can see why they've done it.
Jim the Jim
18 Dec 2020
Cambridge
I would guess that's the intention: it's saying, "if you're on this train, your route will be somewhere on this map". But to my mind this makes more sense on an Underground service where the train is probably stopping at most of the stations on the diagram, than in a case like this where any given service only covers a small part of the map.
The exile
31 Mar 2010
Somerset
There used to be a service the other way, I seem to remember?
Yes - it used to run in the afternoon until a timetable change somewhere around COVID.
They frequently used to delay the 16.22 ex-Bristol, presumably while they cleared it, meaning I missed my bus!
It was originally a product of the move of MOD procurement from Bath to Filton - though of course services had run that way in the past.
Devonian
10 Sep 2019
Totnes
Aren't these specifically the replacement bus routes for branch lines closed after Beeching? Plus Exeter airport and the recently extended route from Kingsbridge to Salcombe.
DelW
15 Jan 2015
I think they're routes with through tickets available, and times shown in the NR journey planner. (That's certainly the case for Minehead and Bude). That may because they're route replacements as you stated as well of course.
Class 466
5 Mar 2010
Atherton, UK
The average user would think that this implies there are less than 6 trains per day between Newton Abbott & Plymouth. Laughably abysmal piece of cartography
trainmania100
8 Nov 2015
Newhaven
Okehampton is mostly 150 so I'm not sure why that is seen as a regular turbo served route. If I was a customer and saw that map, unfamiliar with train types, id therefore assume falsely that my okehampton train was a turbo...
True 165/166 do occasionally go to Okehampton, but predominantly it's 150 operated. The so in the context of the OP, yes I'd consider it misleading with regards to showing "turbo operated routes".
That aside, the rest of the map is ok but again, silly that Cornwall is in a less emboldened line almost makes it look not part of GWR unless you read the print.
It does say May 2022 on it so I'm happy to be corrected, I remember some sort of unit shift around , but the many times I've been to Okehampton, 166 operated services have not been particularly frequent .......
styles
7 Dec 2014
Gwynedd
Having the bus route numbers is a handy addition, never seen that on a predominantly train map here before.
fandroid
9 Nov 2014
Hampshire
Quite honestly, I think it's stupid.
They should stick rigidly to providing only and all the information that 99% of passengers understand/need.
If we're talking about important minority information like cycle accommodation then the map should indicate that, not give half a clue, requiring additional interpretation, by using just the word "Turbo".
Merle Haggard
20 Oct 2019
Northampton
Around here the Beeching closure replacement buses (for example 409 Northampton - Peterborough and 428 Bedford - Cambridge) disappeared when BR stopped subsidising them, which was a very long time ago.
Benjwri
16 Jan 2022
Might be a selection, it’s not all of them. Padstow for example is not on there.
BayPaul
11 Jul 2019
It doesn't include bus services for non-turbo served stations. Which sort of makes sense if you think this map makes sense!
Parallel
9 Dec 2013
The idea of a ‘Turbo’ rail network map probably made more sense when they were exclusively based in the London Thames Valley to highlight the wider local and commuter services. It’s less good sharing this map when they share the routes with other traction.
