Birmingham Moor Street gate line
Russel
30 Jun 2022
Lichfield
There was a thread last year (now closed) about the lack of ticket barriers at Birmingham Moor Street (https://www.railforums.co.uk/threads/gate-lines-at-marylebone-and-moor-street.248346/post-6212664).
There looks like some activity at the gate line at Moor Street. An area of the concourse has been fenced off. Can I assume this is the planned extension to the gate line work actually starting?
Thanks.
I saw this a few weeks ago and thought the same.
It's long overdue.
TheTallOne
2 Jan 2024
Yes, had the fun of going through moor st this morning, must have been 10+ people in front of me in the queue for a gate, and many queues. More queues than gates, everyone trying to merge.
birchesgreen
18 Aug 2015
Solihull
Yeah thats quite normal, had that fun last Saturday afternoon. :E
Russel
30 Jun 2022
Lichfield
I brought a Birmingham Stations - Stourbridge return last week from Snow Hill, it was printed on the plain white till roll type of paper with a barcode, on the return journey the barriers at Moor Street wouldn't accept it, so if that's a common problem, then it's no surprise there is gateline issues at Moor Street.
giblets
8 Nov 2011
Northamptonshire
Yes, the ticket barriers to the left (on the below diagram) are the existing ones, (though they seem to be replacing the wide exit at the top judging by the diagram).
They have inserted the fence (in blue), so awaiting the barriers (along the bottom of the diagrams) to be installed (these will be facing platform 2)
8stewartt
18 Mar 2013
The barriers on P1 at the bottom of the stairs near the main road have been removed and replaced with wooden boxes, so you can currently access the station via the stairs to P1 with no ticket at all. The P2 side is overdue widening, be good to have two sets one as in and one as out to try and seperate the crowds.
giblets
8 Nov 2011
Northamptonshire
The base of the gates were in Situ yesterday, so hopefully complete soon. That being said, I'm not sure if there is a plan to upgrade the existing gates (i.e open the new gates, then shut and upgrade the older gates) as there seems to be some issues with all the gates having optical readers (unless I missed them installing the extra part already)
BanburyBlue
18 May 2015
I'm fairly sure that not all the gates have optical readers - not sure what's involved in fitting these though?
barbette165
15 Nov 2010
New gates have been installed, although open when I came through this afternoon. The previous 2 wide gates, one for entry and one for exit, have been replaced by 3 gates - two normal width gates, one for entry and one for exit and a bi-directional wide gate.
BanburyBlue
18 May 2015
I’m quite surprised how quickly they are being installe.
giblets
8 Nov 2011
Northamptonshire
The gates 'appear' to be in and fully installed since the end of last week, not sure what is stopping them opening them up (the surrounding area (railings, pavement etc) also seems complete, maybe its a software thing, and need all the gates sorted first?
Lets see what they do with the old barriers, the diagram posted above insinuates the wider gate in the existing line ( at the top of the 'vertical' set in the image, post #6 above) will be swapped for a narrow gate, and as mentioned they don't all have optical scanners.
172007
2 Jan 2021
West Mids
That's good news. Now close the street exit barriers on platform 1 and have the exit permanently closed except for loft failure. So many fare dodgers use that exit and when BTP assist it splits their resources too far.
D1537
11 Jul 2019
North Yorkshire
I mentioned this in another thread, but when I use the train to go to work (once or twice a month) I buy a Coventry-Hawthorns Anytime DR. It is inevitably accepted by the New Street gateline, and inevitably rejected - in both directions - by the Moor Street one.
BanburyBlue
18 May 2015
And it looks like, as part of the upgrade, that they’ve finally added barcode scanners to all the gates.
23 Dec 2023
I would just turn it into a fire exit from Platform 1. But agree it needs to be closed.
barbette165
15 Nov 2010
I disagree, the gateline on platf one provides a very convenient entrance when travelling towards Tyseley and the train is due. I think it’s probably a minute quicker from crossing Moor St to the platform than going via the main entrance and overbridge. Once HS2 and Curzon Street is open, it will provide a much quicker interchange in both directions. (a quick play with calcmaps.com suggests that it is about 250 metres from the rear of platform one topassing the platform one entrance on Moor St if going via the main entrance - 250 metres is about 3 to 4 minutes walk)
23 Dec 2023
That's only fine if Chiltern actually staff it, which they don't. Otherwise it is just a massive fare evasion hole in the station.
david1212
9 Apr 2020
Midlands
I disagree, the gateline on platf one provides a very convenient entrance when travelling towards Tyseley and the train is due. I think it’s probably a minute quicker from crossing Moor St to the platform than going via the main entrance and overbridge. Once HS2 and Curzon Street is open, it will provide a much quicker interchange in both directions. (a quick play with calcmaps.com suggests that it is about 250 metres from the rear of platform one to passing the platform one entrance on Moor St if going via the main entrance - 250 metres is about 3 to 4 minutes walk)
To/from the back door of Marks & Spencer (before closed) if arriving or departing on a southbound train even if a brisk walker using the main entrance takes significantly longer. Looking at Google satellite view there is a train in the platform which is 3+2. I think 196 sets so 24 x 5 is a total 120 metre length. Chiltern units are 23m while class 150 are 20m. The distance between the entrances I guesstimate as 3 cars so ~70m. Doubled gives 140m then add walking around the concourse I concur with @barbette165 that the distance is around 250m further. In addition sets of steps instead of one. Even if very quiet without running I doubt this can be done in less than 3 minutes.
It is several years since I have used the platform one entrance so may be wrong but I thought there were two ticket gates, one entry and one exit. If not while well aware of the limited space is there not room for them? If one was wide e.g. the exit one the supervisor could operate it for entry when required.
MrJeeves
28 Aug 2015
Burgess Hill
Not sure if anyone had posted pictures or not.
SCDR_WMR
17 Dec 2017
Crewe
Ahh that's a much better gate line! Hopefully it will reduce queuing at peak times.
Nova1
26 May 2021
Stratford-Upon-Avon
Good to see these operational finally. Watched a few trains unload including a busy Chiltern service and a WMR service at the same time and throughput much much better than before.
BanburyBlue
18 May 2015
Yes agree - has made a big difference.
I was surprised, once they started, how quickly they were installed and operational.
I got off a train here last week; not as bad as ob previous visits but still a lot of issues with tickets being rejected, and the staff member was asking customer what code was displayed on the screen!
In one case, the staff member said the passenger had to show their Railcard, so clearly they are setting the gates up to reject more tickets than perhaps other gatelines do. The only staff present appeared to be gateline, rather than revenue, staff, so it seemed an odd decision in that circumstance.
Royston Vasey
14 May 2008
Cambridge
I can see how these can become overwhelmed by busy arrivals. There are only a few in each direction. I departed BMO last week and needed the only outbound wide gate, with two rather inefficient, heavily loaded travellers in front with inevitable problems scanning their etickets.
Nova1
26 May 2021
Stratford-Upon-Avon
Yup, could easily benefit from some actual revenue protection there especially at busier times. When I was there, although the throughput was good, it was just one staff member manning both lines.
I have found especially at peak times in the "core" section there's often a couple of RPI teams roaming onboard trains for WMR.
