Birmingham Interchange HS2 station
JamesT
25 Feb 2015
Having two separate stations close together, with trains to similar destinations, called Birmingham International and Birmingham Interchange is just asking for trouble. So many tourists or passengers unfamiliar with the area are going to end up at the wrong one.
I'd call the HS2 station Birmingham Junction. That removes the similarities and is a better name anyway than Interchange.
Alternatively (or in addition to) rename the current station from International to Birmingham Airport for NEC. Harwich aside the general consensus is stations called international have/had/were intended to have international trains not planes. Every other rail served airport station is XX Airport.
Are they that separate? Interchange is the other side of the NEC from International. There will be a people mover connecting it all up with an end to end time of 6 minutes.
Sure, but with the people mover every 3 minutes you could get from one to the other faster than walking between the extremities of some large stations.
Really? Its going to be a 20-25 minute mandated connection between the two of them. Easily 5 to get to the people mover from a platform as assuming one is waiting, 10 on the people mover, 5 at the other end.
Baxenden Bank
23 Oct 2013
What is the purpose of the interchange station? Are we/they building a quite large, quite expensive white elephant?
Okay, the clue is in the name but interchanging from where to where?
HS2 and beyond via the WCML connection (if ever built) will have direct services to London so no need to interchange. Will people from the north WCML interchange to double back to Curzon Street or transfer via the shuttle to International then New Street?
If on a west midlands area train calling at Birmingham International surely it will be quicker to remain on that train / change to an Avanti (post HS2 version) to Euston than having a 20-25 minimum interchange with all the hassle that entails.
I can see demand from car-based users from a very wide area, some from the local population plus of course the NEC and the airport.
Is it essentially a humungous parkway / park-and-ride station sexed up as an interchange?
SCDR_WMR
17 Dec 2017
Crewe
It's in a huge area of development, on the edge of Solihull conurbation. There will be buses aplenty as well as the people mover to join the Cov corridor services.
Land gets handed over in 2030 for the Arden Cross development.
Tobberz
9 Jan 2018
I agree that Birmingham International should be renamed to Birmingham Airport. If that happens, then I think "Birmingham Interchange" would be fine -- avoids the two Birmingham Ints.
My more controversial view is to call the HS2 station "Birmingham Airport (Highspeed)", but I realise that won't catch on.
Baxenden Bank
23 Oct 2013
Yes, but will they use it, is it attractive to whizz between Old Oak Common and Birmingham Interchange to them bumble along at either end to reach your real destination. Are the time-savings of HS2 outweighed by the time-lost?
SCDR_WMR
17 Dec 2017
Crewe
Plenty of people will use it. Depending on timetables, it will be far preferable to those that side of Solihull compared to using local stations such as Hampton-in-Arden, or using Solihull/Widney Manor for getting into the city centre.
The Arden Cross development is huge too, with the aim of creating high paid medical jobs etc, there is no time lost if you plan on starting/ending your journey at Interchange.
JamesT
25 Feb 2015
It has been somewhat hamstrung by the curtailment of HS2. If the full scheme was being built, you would have traffic from the West Midlands, potentially as far down as Oxford changing for HS2 services to Manchester, Leeds, Scotland. Previously they would have gone via New Street. Some of that may still use Interchange, but the journey time advantage won’t be there as much.
William3000
24 May 2011
Cambridgeshire
It also brings Birmingham Airport within the orbit of London airports. Journey times will I suspect be comparable or quicker than they currently are from central London to Gatwick and Stansted.
Tobberz
9 Jan 2018
This is very much so. As someone living in West London, Birmingham Airport could easily become preferable on time grounds.
Not central London in its broadest sense, but certainly some parts of London in terms of the time from station kerbside to terminal.
absolutelymilk
18 Jul 2015
From Heathrow, really?
Yeah not sure how this is possible, even if you lived next to OOC station then it would be about 25 minutes via Elizabeth Line to Heathrow. OOC to Birmingham Interchange was around 35 minutes IIRC, so not much more but still not quicker!
TrainTraveler
3 Aug 2024
If it were in the GWR days it would be "Birmingham International Road" or similar.
A station not near the named place.
William3000
24 May 2011
Cambridgeshire
Not quicker than Heathrow but budget airlines for example don’t fly from Heathrow so Birmingham may be quicker than Stansted, Luton, Gatwick which do!
Horizon22
Jobs & Careers
8 Sep 2019
No, from Gatwick or Stansted.
Oh well yes, of course that’s a bit of a difference!
Not sure about Stansted though, with Elizabeth line to Liverpool St and Stansted Express? It does of course depending where exactly in “West London” you are.
Also it doesn’t matter when you’re necessarily going - a new high speed railway line is evidently going to improve connectivity for routes involving London-Birmingham as opposed to the status quo
pelli
15 Sep 2016
Stansted Express is actually relatively slow (at least 46 minutes from Liverpool Street to Stansted Airport), making it "farther away" than Gatwick (at 40 minutes on Thameslink from Farringdon to Gatwick Airport), even if you don't include the extra 3 minutes on the Elizabeth line from Farringdon to Liverpool Street! (For comparison, Luton Airport Parkway is 35 minutes from Farringdon on Thameslink, or 22 minutes from St Pancras on EMR / Luton Airport Express, which is then followed by a 4-minute DART ride to the airport itself.)
Been a HS2 press release that the 3 viaducts on the southern approaches to Birmingham interchange have been completed.
HS2 engineers have completed three major structures on the southern approach to Interchange station, illustrating further progress on the West Midlands section of Britain’s new railway.
The trio of viaducts - Balsall Common, Marsh Farm and River Blythe - are all within the Solihull metropolitan borough.
In the coming days, engineers working for HS2’s construction partner, Balfour Beatty VINCI, will install the final parapets on the River Blythe Viaduct – the largest of the three bridges that carry the high-speed railway through Solihull, and the closest to Interchange Station – approximately 1.5 miles away.
Marsh Farm Viaduct was the first of these neighbouring structures to reach completion in summer 2025. The main structure of Balsall Common Viaduct was finished earlier this year, and all 304 parapets will be installed by spring 2027.
snowball
4 Mar 2013
All three viaducts are of course 2 tracks wide. The Blythe viaduct is the most northerly of the three. Immediately after it, going north, the line widens to 4 tracks because of the approach to Interchange. The wide formation is visible in the Blythe video. The north end of the viaduct is where the river goes under, the south end is where the road goes under.
A new drone video of Birmingham Interchange HS2 station construnction site
Lots of Earthworks, a bridge over a stream, an overbridge spanning the site, and what appears to be a retaining wall alongside the platforms.
Work on the new A45 overbridges can be clearly seen ind looks like one half will soon be ready to have road, allowing slewed carriageway to move over
No sign of any platform works or station buildings yet, although appears the site has been levelled out where platforms will be.
I think it is 2 island platforms flanking 2 through tracks (6 tracks) with parallel movements possible to/from delta junction.
