Birmingham [BHM] to Reading [RDG]
Old Timer
24 Aug 2009
One for the clever chaps.
Can anyone suggest the best split ticket options for the above journey, please ?
Travel outwards prior to 09:00 returning after 16:00 same day, possibly after one or two day break. Regular journey for a couple of weeks.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Banbury, definitely. I've just looked at it for a day return (so not exactly what you want, but the price structure should be similar).
Birmingham Stations–Reading is £75 return
Birmingham Stations–Banbury is £18.10 return
Banbury–Reading is £20 return
Total £38.10, net saving £36.90
MidnightFlyer
16 May 2010
Indeed, though in some cases, it may be cheaper to split at both Coventry and Banbury, it depends on when you are travelling.
With an Anytime Return it is cheaper to split twice (as above), but with all other tickets it is cheaper just to split at Banbury only.
David Goddard
8 Aug 2011
Ely
There appears to be no Returns for this route that let you return after a period of time. Only the Day return, therefore you may have to book singles if unsure when you will return.
For the day return then split as above.
route:oxford
1 Nov 2008
Banbury, definitely for split tickets.
If you're doing the journey week commencing 22nd August...
A 7 day season ticket between Birmingham Moor Street and London Marylebone at £127.00 *might* work, change at Didcot Parkway for the Chiltern Service.
Someone with a comprehensive understanding of the NFM and easements during engineering works will be able to confirm for sure.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Depending on how early you need to be in Reading, it may be worth splitting again to take advantage of the times at which the CDR becomes available. E.g. Banbury - Reading and Oxford-Reading CDRs become available at 0900, but Banbury - Oxford CDR becomes available at 0845. So if you got, for example, the 0803 from Birmingham New Street (arr Reading 0939), which departs Banbury 0855 and Oxford at 0916, it would be worth spltting:
BHM-BAN SDR @ £18.10
BAN-OXF CDR @ £5.30
OXF-RDG CDR @ £7.90
Total £31.30
A weekly season Birmingham to Reading is 40p cheaper at £126.60...
route:oxford
1 Nov 2008
BAN-OXF CDR @ £5.30
OXF-RDG CDR @ £7.90
Total £31.30
I didn't even look...
That's far cheaper than I was expecting!
Paul Kelly
16 Apr 2010
Reading
Well it's a regulated fare, so CrossCountry can't whack it up as they'd like to I suppose!
John @ home
1 Mar 2008
That's odd. When I went to look at it just now, it's coming up as £273 for a 7 day pass from Brum to Reading.
£273 is the First Class 7-day season ticket price Birmingham - Reading route Oxford.
It is evident that CrossCountry are keen to increase prices on this flow, to the extent that they are allowed to.
National Fares Manual said:
Birmingham Stations - Reading route Oxford
NFM07 Sep 2010 - Jan 2011
7-day Standard season £116.30
No First Class fare.
NFM08 Jan-May 2011
7-day Standard season £126.60
7-day First Class season £248.80
NFM09 May-Sep 2011
7-day First Class season £273.00
NFM10 Sep 2011 - Jan 2012
wintonian
15 Jan 2010
Hampshire
When using XC on the Bournemouth to Birmingham route split ticketing at nearly every routing point on the way can be the cheapest option depending on what you want.
It best to avoid paying any fare priced by XC as there will almost certainly be a cheaper option, however I also find some of FGW's fare rather pricy so a split at Basingstoke is almost inevitable when leaving SWT land.
Via London options (mostly priced by VWC) where they exist are cheaper or only slightly more expensive than those priced by XC and are to be recommended in order to boycott overcrowding and poor service.
route:oxford
1 Nov 2008
That's very odd. I was searching for various combinations of Oxford-Bicester-Bicester-Brum at the time. Positive that I didn't select 1st class.
Ah well, the fares match up now, I must have chosen 1st.
bb21
Emeritus Moderator
4 Feb 2010
Avantix gives NFM07 First Class weekly fare as £248.80. Indeed the same prices for Standard and First apply to NFM05 and 06.
David Goddard
8 Aug 2011
Ely
It best to avoid paying any fare priced by XC as there will almost certainly be a cheaper option.
I did that for a friend that wanted to travel from Reading to Liverpool the other Saturday. Got a £74.20 fare down to £47.00, albeit with a combination of four tickets, one of which was a day ranger- the saving was half of his match ticket!
