Bi directional platforms
ijmad
7 Jan 2016
This might be a stupid observation but technically speaking, aren't all terminal platforms 'bi-directional'?
plugwash
29 May 2015
That rather depends on both what you mean by "terminal platform" and what you mean by "bi-directional".
Mcr Warrior
8 Jan 2009
Well, you can normally only ever depart in one direction from a terminal (buffer stop) platform. Whereas a bi-directional platform suggests possible departures in either direction.
billio
9 Feb 2012
Malton has a single bidirectional platform on a two-track railway line. Which made me think about York where the 3/4 combined platform (one physical platform) could be regarded as tri-directional. Penryn has a single platform, but services in each direction use a different part of the platform so trains can pass at the station. Is that bidirectional?.
androdas
3 Aug 2011
The Winning
This is going to be a long list! In the Newcastle area we have Newcastle Central & Manors which is fully bi directional and used (semi) regularly along with Durham (Not regularly used Bi-Di). Morpeth and Chester-le-Street are bi-directional thanks to SIMBIDS (Simplified Bi-Directional Signalling) so can be used Bi-Di during disruption but not regularly Bi-Di.
Sunderland is a curious one as its Bi Driectional but has 2 platform faces divided into 4 platforms to segregate mainline and metro which share track through the station. Metros will regularly go over to the 'wrong' platform to get around a Grand Central service while it is waiting in the opposite platform.
Oh and Seaton Delaval & Ashington as they only have one platform each.
saismee
20 Oct 2023
Ipswich 1, 2, 3, and 4. 1 is a bay platform, all host local terminating services (Cambridge, Ipswich, Lowestoft, Peterborough, Felixstowe). 2, 3, and 4 has intercity services as well as Liverpool Street stopper services.
Sheridan
11 Jan 2012
On the North Wales Coast, there’s Flint, Prestatyn and Rhyl. And Llandudno Junction. Plus Conwy up platform I suppose, technically, as trains can enter it from either direction. They can only leave in the up direction though.
Edit: don’t know how Bangor slipped in there, it’s no bi-di unless we’re counting shunt signals which I’m pretty sure were not!
Pokelet
5 Sep 2017
I'm not aware that the GWR mainline platforms at St Davids - 4 and 5 - are bi-directional, at least not in regular usage.
Worcester Foregate Street is probably the classic example of a station where both platforms are bi-directional.
However, presumably any station with a platform on a single track section of line will be bi- directional.
And also Worcester Shrub Hill P1&2.
Foregate street is (I believe) technically 2 single lines passing through the same station.
ijmad
7 Jan 2016
Surprised no-one has mentioned London Bridge platform 2 yet, this is used during the peaks for Cannon Street services, up in the mornings, down in the evenings.
Northampton
Platforms 2-4 and 6 at London Bridge are fully Bi-di (although not always for the same destinations!) Platform 7 allows wrong-direction arrivals but it's appears (though unconfirmed) it won't allow a wrong-direction departure. Platforms 5, 8 and 9 do not allow wrong-direction arrivals but do allow wrong-direction departures for reversing trains.
Platform 1 is single-direction (Down) only, Platforms 10-15 are bays.
