Best spots for semaphore signalling in 2016
Tim R-T-C
23 May 2011
Hi all,
With Barnetby going colour-light in 2016, I was just wondering which stations will now provide the best viewing points for semaphore signals and how long they have before they too get modernised.
I can contribute Hellifield which still has wooden post signals and a classic station building and roof, although it is lightly served and freight traffic is inconsistent. No plans to modernise at present as far as I know.
ac6000cw
10 May 2014
Cambridge, UK
East of Norwich (towards Yarmouth and Lowestoft) - Brundall in particular has semaphores and a crossing keeper as well for the hand swung gates.
Also Ely North Junction (exclusive) to Peterborough (exclusive) e.g. Manea, March x 2, Whittlesey (or Whittlesea)
Hi all,
Cornwall - probably the best remaining
Gilberdyke-Hull
North Wales Coast (mostly colour-light, but some fine signal boxes)
Carnforth-Barrow-Maryport
Peterborough-Melton Mowbray
Grantham-Skegness
Newport-Hereford-Shrewsbury
Shrewsbury
Worcester
Yeovil Pen Mill
Newcastle-Carlisle
Ayr-Stranraer
Cupar-Aberdeen-Inverness
Harrogate-Poppleton
Hellifield-Carlisle
Blackpool North line
LowLevel
26 Oct 2013
Bit remote but Grindleford, Earles Sidings and Edale on the Hope Valley line are all very busy boxes and mostly all semaphore signals.
Are there many stretches of track with three or more running lines that are still semaphore signalled?
kevconnor
22 Apr 2013
People's Republic of Mancunia
I was at Whitehaven last week and was surprised by the set up there. on the single through line in the down direction there is a light signal (can be seen here), But in the up direction there is a semaphore signal (can be seen here
Is this unique to have both types of signal in one location?
Nippy
13 Aug 2013
No it's not unique matey.
scott118
24 Feb 2015
East Anglia
beware of the dalek's at Reedham, should you venture out that far...:lol:
380101
18 Feb 2015
All the signals between Dumfries and Hurlford (closed) are semaphore apart from the distant signals which are colour light signals, and the intermediate block signal between Hurlford and Mossgiel tunnel which is LED colour light.
The combined home/section signal at Mauchline signal box on the Up line is colour light with all the other signals in that area being semaphore.
Railsigns
15 Feb 2010
There are also a few colour light stop signals at New Cumnock (as well as semaphores).
Hurlford signal box is still officially open but is normally switched out and unmanned.
Crossover
4 Jun 2009
Nope Harrogate has semaphores at the York end of the platform and colour light towards Leeds
380101
18 Feb 2015
I forgot about those New Cumnock ones(bad, as I sign that route :oops: ). Very rarely at Red nowadays on the up/down lines as the coal traffic from Greenburn opencast mine is almost non existent.
Hurlford box is unlikely to ever be open again I think. Would take a big effort to open it for use as the windows are all boarded over. The junction there that went into some sort of goods depot has been lifted so no real reason for the box to be in use now.
23 May 2014
IIRC the gantry at the north end of Shrewsbury station has 1 semaphore signal (platform 3) and two color light signals (through road and platform 4B).
Most other signals at Shrewsbury (except platforms 6 and 7) are semaphore including two center pivot examples at platform 7A and a relatively new signal at the south end of platform 3
Lockwood
4 Apr 2013
Ryde St Johns Road has both signalling types (or did when I was there a few months back)
Freightmaster
Verified Rep
7 Jul 2009
Just as an aside, the semaphore signal above is actually fixed at danger.
I know it's quite common to have fixed red colour light signals these days
on platforms to enable trains to turn back, but is Carnforth the only example
of a fixed semaphore (non distant) signal on a main running line??
MARK
Esmenfif
13 Nov 2015
Leuchars is a good spot. Has a box and semaphores. One can hear the strings pulling the signals from the platform.
blotred
10 Apr 2015
I'm not sure if it has been modernised yet, but the Dudding Hill Line as it passes through Gladstone Park still had semaphores last time I checked.
Worth a try next time you are in Suburban North London.
driver_m
8 Nov 2011
MARK
Holyhead platform 3. There's a fixed semaphore there.
Lockwood
4 Apr 2013
Can't they just use a stop board?
Is there a functional difference between them?
Edit again... I mean a red circle stop board, not an X Car Stop one.,
Crossover
4 Jun 2009
It acts as a stopping marker for the incoming movement, which is running against the normal flow of traffic.
/why the need to have a green lens on it? Is it just a case of standardised parts?
Also, are these fixed danger semaphores connected to the box or not (presume not)
Railsigns
15 Feb 2010
Usually, there's no green lens fitted, like the fixed signal that used to be at Hednesford station (photograph here).
There is no connection to the box other than a lamp repeater circuit, where provided.
craigybagel
25 Oct 2012
For some reason the Bay Platforms (5&6) are colour light, but the through platforms (4&7) are semaphore for movements in the same direction.
How does a fixed signal allow a train to turn back?
I do wonder if Holyhead is unique in being a fixed semaphore stop signal with a working subsidiary signal, which controls access to the run around loop.
