Best scenic routes in Wales
route101
16 May 2010
This thread is giving me ideas for next weekend, using the multi operator ticket. Any good ideas for circular trips starting and finishing in Cardiff or starting in Newport and finishing in Cardiff?
duncombec
3 Sep 2014
Not so much for the scenic nature of the routes, but is anyone able to confirm whether this map from 2018, still available on the relevant website, is still more or less accurate? https://www.visitswanseabay.com/wp-content/uploads/2018/05/Adventures-in-Gower-2018.pdf
The web address on the "back" is wrong (.com is a junk site, .co.uk is correct!) also leads to a promising looking list of downloads of First services (https://swanseabaywithoutacar.co.uk/downloads-timetables/), but they also date from 2018/19!
Also, can anyone advise on the position with the 116? Bustimes helpfully shows it as a joint operation between NAT and DANSA, but DANSA themselves don't mention on their website (then again, they also still list Swansea Bus Station as closed, which I rather hope it isn't). Are their journeys (presumably anything not shown by NAT on their single-operator service) run by a "proper bus", or are we looking more at elbows only on a welfare Sprinter?
Thanks!
Bristol LH
6 Aug 2017
Yes, it is. Service 14 is now operated by Adventure Travel, rather than First Cymru, and the service between Swansea and Three Crosses is now numbered 22, and operated by South Wales Transport instead of First Cymru.
Swansea City Bus Station re-opened in July 2020.
Adventure Travel operates all journeys on Service 116 up to about 1930, using MANs, MetroCitys and the occasional Enviro200. DANSA operates the journeys after about 1930 using a Mercedes Sprinter because patronage is so low.
daodao
6 Feb 2016
Dunham/Bowdon
The bus over Caerphilly mountain is quite scenic; I used to use it regularly (2000-2005) to travel between the Heath and Caerphilly Miners' Hospitals.
For a longer trip, i would suggest (Saturday only): Cardiff-Newport-Chepstow-Monmouth-Abergavenny-Brecon-(Merthyr Tydfil)-Cardiff. Buses to/from Monmouth (including buses direct from Newport to Monmouth) are infrequent, so checking timings in advance is desirable.
On Sunday, the coastal route from Cardiff to Bridgend via Llantwit Major (NAT 303/304, hourly Mon-Sat, 2 hourly Sun) is quite scenic in parts; one can travel onto Porthcawl and return via Cowbridge (First X2, hourly).
TheGrandWazoo
18 Feb 2013
122 Cardiff to Tonypandy
172 Tonypandy to Aberdare
9 Aberdare to Merthyr
1 Merthyr to Bargoed
X38 Bargoed to Pontypridd
T4 Pontypridd to Cardiff
If pushed for time Merthyr to Cardiff on the T4
Just posted about the 172 in the trip report thread
route101
16 May 2010
Thanks for the info. I ended up travelling on the valley lines rather than the buses. But next time I will sample the buses.
DaveHarries
12 Dec 2011
England
The T4 north of Merthyr is also spectacular
I did wonder if somebody would suggest the A470 Merthyr Tydfil - Brecon: it is one of my favourite roads in Wales because of the scenery. If you were looking for scenic routes to cover by forms of transport other than a bus then another one I commend to you is the A465 between Glynneath and Neath: this one is best done in the down direction which is more scenic than going up the valley. The Maerdy and Rhigos mountain roads are also favourites of mine, the Rhigos more so. If you like driving along wooded routes then the A40 road is a good trip between Brecon and Llandovery, via. Sennybridge and Halfway: this one is covered (between Brecon and, I think, Sennybridge) by the Traws Cymru T6 route.
I enjoyed a run on Traws-Cambria from Llandrindod Wells to Newtown via Llanbister and back last week. The bus from Llandrindod to Aberystwyth is also a fine scenic ride (though it goes via Capel Bangor and not the even more scenic route via Devil's Bridge). Most of the mid-Wales routes from Llandrindod and Rhayader are scenic.
Agreed about the Llandrindid - Aberystwyth route, at least in part. My employer sent me up to Aberystwyth a few weeks back and my GPS sent me back along the A44 between Aberystwyth and Llangurig, via. Capel Bangor, which I think is the stretch you refer to. It is indeed well worth the trip. Google Maps says that the A44 stretch in question is covered by routes X47 (Celtic Travel) and 525 (Mid-Wales Travel) but I am not sure if that is currently the case.
Dave
