Bee Network Service/Route Discussion
Cavendish1
3 Apr 2019
The 2 core routes between Ashton and Stalybridge are the 237 and 348 (there are other less direct). On a Sunday, each is an hourly service, why do they have to leave Ashton at exactly the same time? Hoping someone in the know could suggest a way to change this!
mangad
20 Jun 2014
Stockport
Why? Probably because the timetables are based on the previous pre-Bee Network services, and services weren't coordinated between the previous operators (First for the 348 and Stagecoach for the 237).
The obvious route to change would be the 348 as it's the shorter route. You could adjust its timetable to run 30 minutes later, from Ashton, leaving a 20/40 minute gap from Stalybridge. Which sounds nice and easy expect the 348 journeys are interworked with other routes, such as the 350. So you'd have to change that timetable, and what are the consequences of doing that?
Not to say it can't be done. Nor that it shouldn't be done. It's just that it's not simple.
mayneway
29 Mar 2024
Manchester
Similar with the 231 and 230 running through littlemoss. Both always seem to end up running together which seems a bit pointless.
Statto
8 Feb 2011
At home or at the pub
Its not that easy to retime the 237 either, buses on that route interwork with other routes too, 230/231 being a couple of them.
mangad
20 Jun 2014
Stockport
There's plans to do full network reviews in every area, so that's probably the best point for them to review this stuff.
TheSmiths82
29 Jun 2023
Manchester
The 25 and 23 are similar too, they both leave Chorlton around the same time, and they both go to Stockport which is so annoying considering the services are not too regular. I know the routes are very different between Chorlton and Stockport, but a lot of people that get those buses are going to Stockport anyway. That said I personally prefer the 23 as it is a nicer journey.
Xenophon PCDGS
17 Apr 2011
Doesn't the 25 cover areas of Heaton Moor and also later on passes Barlow Moor Road tram stop?
Redmike
13 May 2018
The 348 would seem to make more sense being run from Ashton depot now rather than Oldham.
Statto
8 Feb 2011
Yeah, although the 23 & 25 have common section Chorlton to Stretford, they're both go on different routes, as shown on the Manchester South bus map.
https://assets.ctfassets.net/nv7y93...3c9222131d71c74a1ea1/Manchester_South_map.pdf
The 25 is the Southern section of the old 22 Stockport - Trafford Centre - Bolton, the 22 was a joint Stagecoach/First Manchester route but was split at Trafford Centre in 2017, when the joint service finished, the Northern section became the 2 before being renumbered back to 22, & Southern section was renumbered to 25 then later diverted via Lostock replacing 23A.
mangad
20 Jun 2014
Stockport
There's more than a few routes where the routes are assigned to a large franchise and the depot allocations seem to make no sense. Ashton does multiple Stockport school services, and the 382 which runs Stockport to Woodley.
There must be reasons why, but whatever they are, they're not obvious.
py_megapixel
5 Nov 2018
Northern England
Several routes seem to have been removed from Stockport depot and spread around elsewhere - for example, the 313 and 368 that were moved to Wythenshawe and Sharston respectively. It's perhaps strange that the 330 didn't get the same treatment, given there's an obvious alternative depot to run it from (Ashton) and it would have avoided leaving Stagecoach with that small nonstandard fleet of Wrightbuses. I can only speculated as to why this was done, but I would imagine it had something to do with the delays being encountered in relocating/electrifying Stockport depot.
And then there are various relics of deregulation, such as the 38 being operated from a different depot to the 35, 36 and 37; the dead runs from the very busy Bolton depot for the V1/V2/V4 routes; I'm sure I could go on.
mayneway
29 Mar 2024
Manchester
The 330 was for many many years an Ashton depot service that moved to Stockport on changeover night.
Stranger still is the fact they have all the little Marple and Mellor circulars to Diamond when it would have made more sense to run them out of Stockport .
mangad
20 Jun 2014
Stockport
Yeah, I doubt TfGM were anticipating that Diamond would hoover most of the small franchises up and run them out of Eccles. It will be interesting to see what happens with the small franchises when they come up for renewal. After all, there were hardly loads of SME bus operators left in Greater Manchester, and it's hard to imagine who would bid for a small franchise next time. No new SMEs are going to be created on the hope they may win. Belle Vue and Vision Bus are about the only obvious contenders. Maybe a coach company already doing schools contracts may decide to try their luck. But without some change, then the chances are they'll simply get outbid.
Of course, by that point the politicians may simply decide to bring things in house. Who knows.
That said, the Mellor bus was run from Eccles by Little Gem for a while, and then from Macclesfield by D&G, so in some respects, nothing's changed!
Simon75
25 May 2016
Would a orbital/London Superloop style service work for the Bee Network?
pokemonsuper9
20 Dec 2022
Greater Manchester
Some of the routes already exist, but a Leigh-Bolton-Bury-Rochdale-Oldham-Ashton-Stockport-Airport-Altrincham-Trafford Centre-Leigh superloop style upgrade would probably not go unappreciated.
pokemonsuper9
20 Dec 2022
Greater Manchester
Why is Wigan said to be ignored, when you consider the number of services operated from that bus station and remember that Leigh was incorporated in this proposal. Wigan is as much an integral part of Greater Manchester as Rochdale is.
I put it out to avoid having a service closely paralleling the train between Wigan and Bolton.
An actual proposal would be done in much more detail than 2 minutes of thinking.
johncrossley
30 Mar 2021
Obviously there was the long running 400 Bolton - Bury - Rochdale - Oldham - Ashton - Stockport limited stop service which ran from 1970 to 2004 so I'm sure many people have requested that TfGM brings this back. At times this went to the airport as well. Before deregulation there was also the 401 Wigan - Bolton - Bury - Middleton - Oldham which some time after deregulation no longer went to Wigan but was extended to Stockport instead. So these were quite similar to London Superloop but the frequency was much worse. London Superloop routes generally run every 12-15 minutes most of the time, even on Sunday evenings. Whereas the 400 and 401 were hourly, although it was half hourly on common sections of route.
mattb7tl
1 Jan 2022
Huddersfield
It would work now for West Yorkshire, Greater Manchester, West Midlands, and South Yorkshire (it would be more of a 'super triangle' shape in South Yorkshire). They have major towns circulating around the edge of the region with routes which are already core services with high frequencies. It would really only need a rebrand and a couple frequency lifts for the weakest links.
In the remaining metropolitan counties (Merseyside, Tyne & Wear) the whole superloop concept of connecting the outer towns does not make much sense as they don't really have the towns to connect as these regions consist of a massive urban centre and a few minor towns. It wouldn't end up creating a loop and it would struggle to be sustainable and frequent without substantial indefinite funding compared to the other four metropolitan county where what would be the superloop services are already known to be money spinners.
pokemonsuper9
20 Dec 2022
Greater Manchester
Look at the map - it’s on a limb rather than anything more sinister!
Indeed, the rough sketch is almost a circle. (+ a circle for reference) (map from https://www.systemonetravel.co.uk/assets/public/downloads/S1-Travelcard-Guide-March-2023-WEB.pdf)
Map of Greater Manchester with names of some significant towns, the route between Bolton-Bury-Rochdale-Oldham-Ashton-Stockport-Alttrincham-Leigh-Bolton roughly matches a circle.
Compare to the superloop, which is also quite circular (map from https://www.geofftech.co.uk/downloads/SuperloopMap.pdf).
Map of London with the superloop bus routes showing
Looking at the Manchester high frequency bus route map (And filling in the gaps where there's nothing already), the loop as I described could be done with 582-471-409-330-313-288-245-126.
johncrossley
30 Mar 2021
These routes exist but as stopping services. So if limited stop services are introduced along the lines of London Superloop then you have to decide what you do with the existing routes. TfL have, with a few minor exceptions, left the existing routes alone but clearly the Superloop routes have taken some (and possibly many) passengers away from them.
Xenophon PCDGS
17 Apr 2011
In real life, if such a proposal came to the attention of Mayor Burnham, how do thread contributors feel that his reactions might well be?
Looking at what tranport modes the settlements on the proposed route already have in addition to bus services....
Salford.................Train and tram
Manchester...........Train and tram
Stockport.............Train
Ashton.................Train and tram
Oldham................Tram
Rochdale..............Train and tram
Bury....................Train and tram
Bolton..................Train
Leigh...................Guided busway.
pokemonsuper9
20 Dec 2022
Greater Manchester
Yes but none of those directly parallel the proposed bus route (except tram Rochdale-Oldham).
I don't see why the 610 or 609 and 575 couldn't also be included in a loop style service, I just didn't put it in originally.
py_megapixel
5 Nov 2018
Northern England
According to signage, some of the departure stands at Stockport Interchange are to be rearranged from Sunday 20th July. Stand Q, the one stuck out on the opposite side from the main part of the station, will no longer be used for the 199, 313 and 391 routes. This is significant because it eliminates an extra loop round the bus station one-way system that those services have to do in order to serve stand Q and then exit the station at the Mersey Square end.
IMO this change is sorely needed (in fact I wrote about the issue on this forum a few months ago) - given that extra loop has to be done at 5 mph, stopping repeatedly to give way to arriving or departing buses, it can sometimes add 5 minutes or so to the time taken to serve the Interchange. Particularly on the 313, which is rather tightly timed and often seems prone to unreliability, being forced to spend several minutes of each trip driving round in circles is highly unwelcome
sprunt
22 Jul 2017
Why does the 41 have a diversion away from Oxford Road around the MRI on Friday and Saturday evenings?
EDIT: Sorry for posting this in the London thread, don't know what happened there, I was sure I was in the Bee Network thread.
johncrossley
30 Mar 2021
Severe congestion in the Rusholme area due to illegal parking. Also affects other routes which normally go through Rusholme.
I also didn't notice this is the London thread! :)
