Back in the 60's BR had a problem with the brake force of diesel locos restricting loads that could be hauled. The solution was to create brake tenders. These were basically cut down and shortened old carriages filled with concrete. Coupling these to the diesels provided more braking capability.
We currently seem to have a situation where there is a surplus of modernish EMU's (eg 350/2), some DMU's which are reaching life expiry, and a general wish to reduce running diesels under the wires.
Hence I wonder if it would be viable to take the original brake tender concept but fill with batteries rather than concrete. Then couple these up as required to an EMU with a power connection so that the EMU "thinks" it's drawing from the OHLE or third rail. I would have thought that this would be considerably simpler and cheaper than the work needed for the 769s.
Is this bonkers?
Is this bonkers?
