Battery Powered Trams
GrimsbyPacer
13 Oct 2014
Grimsby
Good article. I personally think the overhead wires are far too costly and prevent new tramways being built in smaller towns due to cost. Parry People Movers have an alternative idea using flywheel energy storage for moving trams without wires for new lines or extensions and I'll recommend you research their page too.
WatcherZero
25 Feb 2010
False economy, overhead wires aren't particularly expensive compared to embedded track and the cost of regularly replacing batteries is huge, they cant even afford to replace the batteries the new routemasters are burning through in London so nearly half are running around with fewer or even none installed.
LexyBoy
23 Jan 2009
North of the rivers
That was my thought - I don't know the figures but installing the OLE can't be that costly compared to the prolonged roadworks necessary for the track.
It's interesting to note that some cities use ground level supply only on central sections, with OLE elsewhere. I don't know whether this is down to cost of installation (which would presumably be mitigated by being carried out along with track installation), or reliability.
Also, one of the benefits of trams is their light weight which would suffer in a "self-powered" version, whether that's battery or internal combustion. These would also have higher maintenance requirements.
jopsuk
13 May 2008
ground level supply is more expensive and less reliable than OLE. It's used only where OLE would be instrusive.
As for Parry, it's worth noting that the company has been around for years, somehow, despite having sold two units
WatcherZero
25 Feb 2010
Parry are more old school engineering workshop, tinkering away on an idea rather than end to end setting out just to design and market a single product. its a sideline to them compared to other things like building materials and 3rd world engineering solutions and they did other people mover/rides before the two rail units.
I think it's cost, not only of installation but also of operation, and also operating constraints. As far as I'm aware none of the ground contact systems works above 50km/h or allows for regenerative braking. There is a potential reliability issue that any failure of the numerous moving parts could leave a short section of rail permanently dead, and for this reason the trams on these networks also carry batteries that can move them a few hundred metres if necessary.
There are other tram networks that have no power supply whatever on short visually sensitive sections, where the trams have to run on battery.
duncanp
16 Aug 2012
The tramway in Bordeaux, France uses a surface contact system whereby there is a conductor rail, but it only becomes live when a tram passes over it.
It is called Alimentation Par Sol or APS for short.
Do a search in Google for "The Bordeaux tramway and APS" for a detailed explanation.
jopsuk
13 May 2008
Yes, the Bordeaux system is an example of the dual-use approach- it uses APS in the historic city centre (which is almost all street running) and overheads on the outer sections (where there's a lot of separate infrastructure and higher speeds are useful)
jopsuk
13 May 2008
Dubai though is not the sort of place that makes sanity-based spending decisions!
jopsuk
13 May 2008
A tram route fully using APS when there's no need to, with air conditioned tram stops (with platforms edge doors) and first class sections.
Busaholic
7 Jun 2014
I believe both Nice and Seville have sections without overhead lines.
simple simon
13 Feb 2011
Suburban London
Dubai is a very hot weather climate and air conditioned tram stops make the wait much more tolerable.
It does use overhead wire - but only in the depot!
Nice has a short battery section but wont be making the same mistake for its next tram lines. Seville uses capacitors which are recharged at tram stops. This is what Nice will do on its next tram lines too.
More information here:
http://citytransport.info/Trams02.htm
Simon
JaJaWa
14 Feb 2013
I took some photos of the super-capacitor powered trams in Guangzhou (CC licensed). You can see a short overhead power rail attached to the roof of each tram stop where the trams recharge, meaning that no OHLE is visible.
simple simon
13 Feb 2011
Suburban London
Busaholic
7 Jun 2014
Those are great pics. Apparently this is the first brand new tramway to use this power supply system. The Doha tramway in Qatar will use the same system.
Simon
Two countries where finance is always available for the right projects:p
9 Aug 2012
The odd thing is when I last visited Qatar, back in the mid 2000s, the whole state was public transport free. There were a few yellow "school bus" type vehicles carrying crews of labourers around, but nothing for general public use. A pain if you were there for work. Now extensive bus networks, light rail, heavy rail, high speed rail all proposed or in delivery - what a change!
Busaholic
7 Jun 2014
Ir's amazing what soaring oil prices can do for a state (combined with a friendship with a certain Sepp). Wonder how many of these projects will fare now oil is under thirty dollars a barrel.
mailbyrail
23 Dec 2010
Oranjestadt on the island of Aruba in the West Indies has installed a tramline powered entirely by batteries augmented by hydrogen power cells. No wires anywhere en route. The first car began service in 2012 and there's now a second car. Electricity for the batteries is from wind and solar, Aruba is aiming to be the world's first 100% green economy by 2020.
Details of the line and cars at http://www.tramz.com/aw/aw.html
