Barking to Gatwick avoiding zone 1
Connacht
29 Jun 2023
Galway, Ireland
TFL state that the off-peak fare is reduced from 13.50 to 10.50 if you travel via Canada Water, Shadwell or Whitechapel.
Does this mean tube from Barking to Whitechapel, then change onto Overground, going south to New Cross Gate?
Do trains to Gatwick stop at New Cross Gate?
A S Leib
9 Sep 2018
No; I think the best option is, depending on how bothered you are about saving twenty minutes, going from Whitechapel to Norwood Junction, which has Gatwick trains every thirty minutes, or changing at Norwood Junction and again at East Croydon.
Benjwri
16 Jan 2022
Bath
You could take the tube to Whitechapel or take C2C to West Ham and the Jubilee to Canada Water, whichever is quicker. You then take a Windrush train towards West Croydon. No Gatwick trains stop at New Cross Gate, the fastest option seems to be changing at Norwood Junction to the Caterham train and then again at East Croydon for a train to Gatwick. If you don't mind a bit longer journey you can change straight to a Three Bridges train at New Cross Gate.
If you search for New Cross Gate to Gatwick in a journey planner it should be able to give options.
Mattplans
27 Sep 2024
London, UK
Realistically what's stopping OP from leaving the train at Whitechapel, scanning the interchange reader on the LO plats and just going via Farringdon provided he doesn't cross a gateline again. Could this even be detected
Connacht
29 Jun 2023
Galway, Ireland
Thanks.
I see 1h52 journey time from Whitechapel to the airport, double what I expected.
Maybe it's faster to pay £3 more and go to a city centre terminus to get a fast direct train to LGW?
It looks like I'm wrong, but I presumed there are trains taking 30-40 mins from the city centre to the airport?
Benjwri
16 Jan 2022
Bath
Thanks.
It's about an hour and a half going all the way into Blackfriars for a Thameslink, at the end of the day depends how much you value the quicker journey.
Connacht
29 Jun 2023
Galway, Ireland
I presumed that LGW is closer than Luton airport.
I now see that Southern trains take 1h18 to Victoria.
I would have guessed 40 mins.
Thameslink trains take 45 mins from St. Pancras and 54 mins from Blackfriars, but that excludes the DART.
mmh
13 Aug 2016
Thanks.
That journey planner result seems to be a rail replacement bus from East Grinstead to Gatwick. What day is this on, as that'd suggest there may be engineering works. Ordinarily, when the line is open, you wouldn't go anywhere near East Grinstead.
Connacht
29 Jun 2023
Galway, Ireland
Sunday 18-Jan.
I intend to travel from Ireland to London that weekend, and I am debating where to stay and which return flight to take.
If you get out at Whitechapel and touch your Oyster on the pink interchange reader, you can save the £3.50. Is this a loophole of the pink reader system? https://www.railforums.co.uk/thread...er-travelling-via-zone-1.270234/#post-6849126
Yes, it is a loophole, but one that the fare structure accepts. If it didn't accept it there would be a barrier line to and from the Elizabeth Line at Farringdon. Farringdon is a bit of an open hole in the system, but realistically not that many people will go to the trouble of getting off a train at a pink reader station, go to the pink reader, and get on the next train. The same applies to splits using Oyster / Contactless.
It can't be detected. The Oyster set up looks at touch in, touch out and any touches on the way. All a user has to do is follow those necessary touches, and travel where they like in between.
Mattplans
27 Sep 2024
London, UK
Sadly it doesn't actually matter, because engineering works on the date op plans to travel means TL are terminating at ECR.
Benjwri
16 Jan 2022
Bath
Sunday 18-Jan.
Ah that will be the issue. There are engineering works meaning the line to Gatwick is closed on the 17th and 18th, and therefore the journey is extended by a Rail Replacement Bus.
mmh
13 Aug 2016
Sunday 18-Jan.
That weekend the line south of East Croydon to Gatwick is closed, which is why it's routing you on a bus and it takes so long. There's an engineering works calendar on the Southern website here: https://www.southernrailway.com/ser...k?date=2026-01-18#engineering-departure-board
I would try to use a different airport, if that's an option.
JamesRowden
31 Aug 2011
Ilfracombe
The timings would be proof of fraud since the timings of the taps would not be possible without passing through Zone 1. TfL could even write some code to not provide the discount if there is too short a time between taps for the discounted route to have been taken.
I don't think the terms and conditions for Oyster / Contactless entertain the idea that using an 'alternative' route is fraud. The parameters for the system are the displacement between origin and destination stations, a maximum journey time, and any touches on the way. Whether you actually avoid Zone 1 in the process is neither here nor there, subject to not using particular gatelines, and certainly not fraud.
mmh
13 Aug 2016
Also, any checking system based around how long a journey 'should' take based on the timetable and how long waits between trains are would be complicated, and never work. You could go via Whitechapel, get to Norwood Junction and join a late running Thameslink train which gets to Gatwick before you 'should' have. In disruption trains are sometimes run fast, missing out stations, and so on.
JamesRowden
31 Aug 2011
Ilfracombe
The TfL is quite explicit in stating that this discount is only for journeys avoiding Zone 1.
Avoiding Zone 1 via Canada Water, Shadwell or Whitechapel
You'd just take the minimum sum of train times for the route and minus 5-10 minutes for added margin. Simples.
Also, a prosecution would not need to be automated. The evidence of repeated fraud would be there to be seen if done consistently.
Mattplans
27 Sep 2024
London, UK
For Op it seems avoiding Zone 1 is the least of his concerns. I would recommend going to Victoria, where you can catch an indirect train to Gatwick if you're reluctant to take luggage on the rail replacement from East Grinstead. But if you're adamant on avoiding Zone 1 you could do Barking > West Ham > Stratford > Clapham (full mildmay line) to connect with this Southern service which are running to Gatwick. Definitely the day to fly from an alternative airport if possible though
mmh
13 Aug 2016
Bear in mind too that the Victoria to Gatwick trains on the 18th and 19th go the very long way around take a very long time - an hour and a half - and are only run every half hour, so may be busy.
Need to also be mindful about the maximum journey time, which is 3 hours 40 minutes on a Sunday, if there is any time waiting on the route.
TfL decide what to charge, not the passenger. If they decide to charge the passenger a lower fare than they mean to, that's on TfL.
Proving fraud is an incredibly high bar and I think it's best you don't postulate on it when you clearly don't understand the TfL PAYG system particularly well.
It's not "simples" at all. As other have said, if you make tight connections onto skip-stopping trains the journey time could plausibly be more or less the same via Canada Water as it is via Farringdon.
RJ
25 Jun 2005
Back office
Think there's a lot of overthinking about the use of the pink reader then going via Zone 1. There are quite a lot of niche situations like this in the Oyster/CPC system where people can work out holes in the system logic and use them to evade part of the fare. Sometimes it's accepted by the powers that be. Sometimes if someone gets too confident and does it regularly, they lie in wait for the person then do them for fare evasion - years back on the TV there was a case of a guy that was also validating strategically to evade being charged for Zone 1 travel, and they got him.
The only time there's nothing they can do is if they define default the default fare route as avoiding Zone 1, but you can go via Zone 1 without any abuse of pink readers or exit gates. There are loads of examples, Whitechapel to Greenwich for instance, it's not unreasonable to go via Farringdon but you'll only be charged a Zone 2 fare.
Surreytraveller
21 Oct 2009
It's not fraud. It's not fare evasion.
For Oyster/Contactless, the only requirements are that you are tapped in, and are within the Oyster/Contactless area.
How you travel between two points is irrelevant.
TfL will charge people for using Zone 1 if they haven't used Zone 1; the opposite of what's being discussed here.
The TfL PAYG system is somewhat simple for a complicated system. It's the price they pay for having the system.
I would love to know what offence they're alleging. Because there's none that I'm aware of. There's nothing in the TfL Oyster conditions (or elsewhere) that says you cannot touch a pink reader and then go via Zone 1, or vice versa.
Thames99
11 Sep 2023
Reading
Quite lot of people must tap pink readers if they are passing one without realising what it is for or whether it needs to be tapped. It would be difficult to prove that this is fraudulent I would have thought.
Mattplans
27 Sep 2024
London, UK
That’s interesting. Why does that happen but for Croydon or Gatwick it will charge you via Zone 1 by default?
Or does that have to do with the DLR/Shadwell?
RJ
25 Jun 2005
Back office
In the TV case, they didn’t explain in detail. The inference was the passenger was doing a journey via Zone 1 on the Underground with a Zone 2-3 Season Travelcard on Oyster. He used this to get through the barriers at both ends and intentionally did an additional validation which stopped him being charged for travelling via Zone 1. The unusual behaviour flagged up with LU Revenue, they then sent a team to wait for the guy who wasn't hard to find as he did the journey regularly and wore bright red headphones.
