Ballast Train bends Bridge
WatcherZero
25 Feb 2010
It looks like the bridge bulged around the bridge deck, ballast packed too tightly perhaps?
Boodiggy
8 Nov 2012
Usually with the HOBC there is a follow up tamper and ballast regulator but the HOBC itself has built in tamping functionality and a DTS to aid in compacting ballast and allowing TSRs imposed post work to be removed quicker. The 09 Tamper (triple bank) also has DTS capability too.
Well this is the case for the newer ballast cleaner not to sure about the older one - not sure what one is used on Anglia - West Coast uses BCS4
Peter Mugridge
8 Apr 2010
Epsom
Looking at the BBC video, that bridge has several braces fitted to it already; the circular black objects on it are like huge nuts on very big bolts that run all the way through the bridge to stop exactly this sort of damage from happening.
Therefore that bridge has a history of being at risk from spreading - does anyone know how long ago the braces were fitted?
Class 170101
1 Mar 2014
Some look to have been fitted as result of the incident according to some shots I have seen.
WatcherZero
25 Feb 2010
Some of the brick work is newer than others, didn't see any braces in the shots I saw of immediate damage.
fat_boy_pete
16 Mar 2015
Essex
ESRs have been raised to 60 for passenger trains on both up & down :D
Thank goodness I can now catch my usual morning train again. :)
Let's the HOBC is operated carefully over any other venerable under bridges down the line.
